Making the transition to tubulars
addictR1
by addictR1
What kind/ brand wise do you recommend?
I’m currently using glue but perhaps using tape on the tufu would be a good idea. Just not sure if mixing glue and tape would be ok or not
KCookie
by KCookie
I use 19mm Tufo tape on my lightweight wheels, usually weighs around 30g per wheel, yes that is heavier than glue but so quick and easy.
Geoff
by Geoff
Generally speaking, the intention of the 'perfect' glue job is to create the best possible bond between the rim bed and the basetape. Accordingly, the better the glue job, the more difficult the tire will be to remove. If you can easily dismount the tire, it stands to reason that such a glue job will also result in a greater likelihood for the tire to become dismounted unintentionally. I would always personally recommend that the tire be glued with its retention whilst riding as the overriding consideration.
Wingnut
by Wingnut
KCookie wrote:
Thu Mar 29, 2018 9:34 pm
Wingnut wrote:
Thu Mar 29, 2018 1:06 pm
Well stuff that! I've been training on tubulars for the last 7 months and got my first puncture today, took me over half an hour to peel the old tyre off and then a nightmare to stretch the spare pre glued tyre on.
I used to race on tubulars over 20 years ago but training on them...f#@&k that! I'm back to clinchers for my training wheels from now on...
Use tape and can have a tyre changed in minutes and im a novice. It's so easy and clean. Carry a tufo tyre, nice a light no pre stretching and you'll be on your way in 5 mins with clean hands.
I think I might have to give tape a go...I glued my tyres on so well it was difficult to say the least. Without the tyre levers I would have been there even longer.
"It's not the destination...it's the ride!"
KCookie
by KCookie
Once you try it i dont think you'll go back. I've got full confidence in tape. Never had an issue yet and on $7k rims to.
sychen
by sychen
Just another soon to be tubular newbie checking in.
My question is more to do with tyre sizing.
In Clinchers.. the wider the rims the wider the spread (in most cases) so my 26mm Specialised turbo cotton on Roval CLX50 measures in at nearly 30mm wide (caliper).
The nice thing about this combo is that the profiles align almost perfectly.
How does tubulars present itself on narrow/wider rims? As there is no open ended part to spread.. I would expect tubs to have some spread on wider rims but not too much?
Using a wider tyre than the rim(narrow) would present a mushroom shape as well?
For instance, on Bora 35s (24.2mm width) is this better paired with (profile wise) 25mm Veloflex Roubaix or 27mm Vlaanderen . I know there are more to tyres than profiles matching the rims.
Does the equation change when going to a rim that are wider?
Thanks for answering questions from a tubbie (tubular newbie).
sungod
by sungod
it's really a matter of how the rim bed radius matches the tub
taking extreme cases...
- puting a large diameter tub on a small radius rim bed (typically on a narrow rim) will mean the basetap will make best contact at the edges of the rim bed, but the centre may not stick so well
- the other way around, a narrow tub on a large radius rim bed will make good contact in the centre but the edges make not even touch the rim bed, this is worse than the first case i think
neither is good, you want a good match for strong adhesion
the diameter of a tub isn't really affected, it is a tube, the internal pressure keeps it circular
on the boras personally i'd go 25mm for road, afaik a tyre bulging out beyond the rim is not good aerodynamically
sychen
by sychen
Thanks sungod.. Pretty much what I thought.
Just wanted confirmation.
Cheers
Sent from my SM-G950F using Tapatalk
addictR1
by addictR1
KCookie wrote:Once you try it i dont think you'll go back. I've got full confidence in tape. Never had an issue yet and on $7k rims to.
What kind/ brand of tape do you use?
KCookie
by KCookie
Hey addictR1.
This is the one I use. Image
sungod
by sungod
blasphemy!
:D
KCookie
by KCookie
sungod wrote:
Mon May 28, 2018 3:25 pm
blasphemy!
:D
I know, my apologies 😀, but it's just so quick and easy even though it's not very WW at between 27-30g a wheel, but I just can't be bothered with all that glue.
addictR1
by addictR1
fingers got itchy and accidently clicked on buy it now... so now i have a new set of DA C40 inbound. here are the tubs i have now:
Veloflex SPrinter 22mm (currently on Aero 72)
Veloflex Carbon 23mm x 1
Aero 72 is 26.2mm wide while the C40 is 28mm wide
the 22mm might be too narrow on the C40... so probably need to buy new tubs.
question is.. can i use the carbon 23mm for front and get a 25mm Arenberg for the rear? was thinking to get the Roubaix but may be odd with black side walls front and tan in the back.
Never had a rim that wide before... so just wanna make sure it's well protected.
i'm also open to trying other tubs as well.. thanks.
addictR1
by addictR1
repost - tapatalk is acting up.
1415chris
by 1415chris
Are these measurements at the brake track?
I run Carbon-Arenberg on 303/404 combo.
303 measures 28mm and 26.5mm at the brake track.
404 26.5mm and 25.3mm respectively.
I had to use Carbon cos my previous frame's fork was too tight for 25mm. And because it is still in a very good shape, I decided not to change it.
If 28mm is at the brake track I would go for 25mm tubs.
For 26.5mm (303) 23mm is the narrowest tub I'd consider. I had to put 22mm (Extreme) couple of times on this rim and it looked weird, too narrow.
