Making the transition to tubulars
sungod
by sungod
yep, that's the downside of latex tubes
in prep for long rides i tend to over-inflate a bit on the basis they'll lose some
addictR1
by addictR1
sungod wrote:yep, that's the downside of latex tubes
I pump my Veloflex sprinter to 110 from and 130 rear... in my 67.5 miles ride, towards the end I can feel the ride is much comfy compared to beginning.. at least the glue job was good. Thanks to everyone's tip
Mackers
by Mackers
What's your weight?
I pump my Vredesteins to 60F and 70R (@130lbs)
110 and 130 seems very high.
addictR1
by addictR1
Mackers, I'm at 152lbs. veloflex sprinters are 22mm wide, so if i pump it 60/70... might be all flat by the time i'm done riding.. haha
Geoff
by Geoff
Still, you'll be much happier at lower pressure...
Shrike
by Shrike
Are you guys using acetone on the inside track when you first get your wheels? What about sanding the surface a bit, is that necessary?
sungod
by sungod
with brand new cf rims i use some 0000 grade steel wool to help remove any mould release compound from the rim bed - they can be quite tenacious - the steel wool can be wadded to match rim profile
this is a one-off with a new rim, it's not to roughen the rim bed
after that, clean paper towels to scrub with acetone or isopropyl alcohol (i prefer this as it doesn't flash off so fast) to remove dust, finger grease etc.
Shrike
by Shrike
Thanks sungod, will go with that :D
addictR1
by addictR1
What's the lowest psi I can run on my Veloflex 23mm without risk getting a flat?
sungod
by sungod
it's not risk of a flat i would worry about, it's rim damage if you hit a hole/edge in the road on skinny tyres at low pressure
too low and the tyre deforms more which is less efficient, and it can feel a bit squishy/squirmy
i'm 77-80kg, 23mm carbons i usually ride around 6 bar, higher if i know the route has a good surface
addictR1
by addictR1
Thanks sungod!
Shrike
by Shrike
Hypothetical here.
Lets say you've got a tubulars stretching on a rim at the moment. Maybe tonight you'd want to try the rim out around the block. No glue or anything on it, just a fully inflated tubular on the rim. Seems tight.
Would a person survive such a thing :P
Really want to try this rim out this evening - sooo windy today. Just to see how it handles (58mm) and will be a week until they're all set up properly (rear wheel hasn't arrived yet.
by Nefarious86
Don't corner if you like your teeth....
Using Tapatalk
Shrike
by Shrike
Hah, alright so super gentle on the corners and should be okay. Well, that's what I want to believe anyway.
If you don't hear from me again.
You know what happened ;P
Geoff
by Geoff
I have actually seen that tried...once. It was just messing-around in the infield at Nationals. Someone (who will go nameless), decided to 'test' whether you could ride an unglued tubular (front). You cannot. Don't do it.
@addictR1, at 150ish, you can very safely run 100/110ish in the dry, and 90/100ish in the wet. If you are running super-deep carbon wheels (I mean the rim bed sidewalls, not just the overall rim depth, like Hed Stingers, or something), then you should run the 25s on the rear, to avoid pinch-flats without sacrificing ride comfort and adding rolling resistance caused by running the rear so hard.
