Making the transition to tubulars
Forum rules
No, not at all. Repairing a punctured tubular is easier and faster than a tube. The challenge is if it doesn't seal. Then either you put a spare (which is tedious) or call a taxi.
I only carry spare on group rides; but I more frequently ride on my own. I ve called a taxi twice. Once with Corsa Speed (completely inadequate for general road riding).
On a separate topic, I think latex seals better that's butyl inner tubes.
Attached how I carry the spare. It is held together with Velcro's, so it is easy to swap from bike to bike.
You should take the plunge, at least try with a cheap pair of wheels. That’s what I did, snagged a carbon tubular for cheap. My first glue job was messed up as I was impatient. I had to pull and re-glue, which was annoying, but I feel like it just gave me more practice.Nicke wrote:The upcoming bike is a rim brake one.
I use tubeless on MTB and gravel but I've heard mixed things about it when it comes to road.
For someone with really no experience with tubulars, is it something I should realistically consider? The wheels will obviously be much lighter, but will the tires themselves be too much of a hassle?
Some people say it’s relaxing, and zen-like, but for me, I just enjoyed the hands on process and learning a new bike-related skill. Ride quality is supposedly top notch but I haven’t taken mine out as I ran out of glue due to the aforementioned glue-mess up.
Oh .. another top tip - use painters tape on the brake track. Your first time pulling the tire on will get glue everywhere and it’s a PITA to remove.
Thank you both for the encouragement.
Never thought I'd say this, but I'll seriously consider tubulars now. Always figured they were a thing of the past, but they can't be that bad right. I'm sure I will be able to find tubular wheelsets for somewhat cheap on the used market since most are moving away from it.
Side note: Would using tape or glue be more beginner-friendly?
You have to ask yourself what are your priorities. If it's ease of use/repair, then go with clincher or tubeless. If you want to ride the best of the best in terms of weight and ride feel and understand the drawbacks (convenience in installation and dealing with punctures) and are not deterred from them, then consider tubular.Nicke wrote: ↑Sun Aug 15, 2021 6:08 pmThe upcoming bike is a rim brake one.
EDIT: oh and there is the issue of rim braking on carbon clinchers if there is threat of overheating/blowing up tubes/blowing off a clincher for heavier riders/big descents that require a lot of braking
Yeah I'll have to give it a good thinker. Obviously I don't voluntarily want to sign myself up for a lot of stress, but I also don't want to pass on the lightness and, as you said, nice ride feel.
Braking shouldn't be an issue - I'm 72kg and live in Finland with a few hills here and there.
I moved to Tubular tyres about two years ago and was certainly worried about changing a flat and gluing for the first time.Nicke wrote:Thank you both for the encouragement.
Orange seal works well to fix a flat but if not then i carry a Tufo Elite and change on the side of the road. Doesn't take long at all.
Personally I would never glue again, i just can't see the point.
Using tape is so quick and clean. One of the tapes I use weighs the same as glue so not a disadvantage for me.
Most swear by using glue and kudos to them, im just crap with glue.
Sent from my SM-G986B using Tapatalk
I'm another tape convert...KCookie wrote:I moved to Tubular tyres about two years ago and was certainly worried about changing a flat and gluing for the first time.Nicke wrote:Thank you both for the encouragement.
So much easier and I use sealant inside as prevention with a Tufo spare in an Arundel saddle bag.
A
Sent from my XQ-AT51 using Tapatalk
FMB make a 34, I think because their US distributor asked them to https://www.renehersecycles.com/fmb-tubulars/ I think they would probably make wider ones if there was enough demand. You could ask Rene Herse if it's likely to happen.DHG01 wrote: ↑Sat Feb 27, 2021 3:51 pmUnfortunately for those who like tubulars, I think the offering will decline going forward. Probably it will do more so within the lower level segment of tubulars; which makes sense. It still amazes me why someone would buy tubular rims today and stick Tufos on it.
On a separate note, aside from Challenge and Dugast, is anyone aware of 35-38 mm tubulars?
- HammerTime2
- Location: Wherever there's a mountain beckoning to be climbed
Thank you, that is useful.eurostar wrote: ↑Mon Aug 16, 2021 9:19 pm
Interesting article also.
I'm sure this has been said, but the point of glue is that if you carry a preglued spare you can do a very, very fast tyre change at the side of the road. Faster than fitting a new inner tube in a clincher. A taped tyre takes too long to remove. Unless your thumbs are as strong as a bodybuilder's biceps.
Edit: alistaird, I just read your post properly...you do actually carry a spare Tufo. How do you get a taped Tufo off in a hurry? I never, ever want to do it again, not even at home! Plus, some of the tape glue will be stuck on the rim, so you have to tape over it, or spend ages removing it with acetone. Aaarggh, no!
I use a lever. I might leave a bit if space near the valve without tape. I haven't changed many tubulars on the road, but it has worked.
As you pull out the tubular you may pull out the tape with it or leave in the rim - I rather pull it out. I then just place the spare. I do ride carefully, but with sufficiently high pressure, I haven't seen the tubular threatens to run off the wheel.
