Open mold wide profile carbon wheels
emotive
by emotive
TLN wrote:
Fri Oct 25, 2019 2:59 am
G-one is for gravel? I see there is newer Pro-one in 30mm, but I guess not many people have it yet.
What's general consensus here about 30mm tires?
Haven't seen any real-world measurements on forums for the new 30mm Pro One, nor the 32mm GP5000. It's only the last year or so that road frames have had room for these tyres. I'm running a set of 32mm Rene Herse on an all road bike. They roll fast and are great to ride, with a very small aero penalty for the 33mm measured width. I expect the new 30mm Pro One and 32mm GP5000 would be fast and comfortable if your frame has clearance for them.
TLN
by TLN
I'm aiming at 32-34mm measured width (and height at this point), so there're bikes that clear that. Looking at BMC Roadmachine, but I know that Venge and systemsix will clear wide tires too.
For a second I was thinking about something even wider and getting 650b wheelset... but I have time to decide.
His: Specialiez S-Works Tarmac SL5 Disc.
musiclover
by musiclover
emotive wrote:
Fri Oct 25, 2019 5:26 am
My 2016 Boardman Endurance SLR disc frame has a clearance of around 40 mm which should allow tyres of around 36mm reald width. Although, manufacturer has no idea about clearances and is not able to advice of the maxmium once. (Just wanted to double check with them to be on the safe side and to know manufacturer's point of view on this subject).
emotive
by emotive
The manufacturer spec is to have 4mm of clearance all round. I squeezed 31mm tyres into my 2015 Defy which officially has room for 28mm tyres. I have about 2mm all round. Ridden it that way for the last 15,000km without any issues.
TLN
by TLN
Yeah, I'll be running slick tires, and ok with tight clearance. Doesn't need to be 4mm all around. I'm pretty sure most of the bikes designed around 28c tires (especially on wider rims) should be okay.
kyleFu
by kyleFu
Many old customers ask if Farsports has promotion for 11.11 and black Friday as last year?
Yea, Farsports has promotion for all rimset and wheelset on web shop during 11th-12th Nov and 29th Nov - 3rd Dec.
Farsports
https://www.wheelsfar.com
kyle(at)farsports.cn
musiclover
by musiclover
Are you planning to create something super wide and hookless? Similar to Enve 4.5 AR?
tonchy
by tonchy
kyleFu wrote:
Sun Nov 10, 2019 3:27 am
Except for KAZE Wheelsets.
kyleFu
by kyleFu
tonchy wrote:
Sun Nov 10, 2019 6:45 am
Kaze wheelset included, Kaze road brake wheel is as section of "Kaze wheelsets" at web shop.
Kaze road disc brake wheel is as section "Gravel disc brake".
Farsports
kyleFu
by kyleFu
musiclover wrote:
Sun Nov 10, 2019 4:30 am
40mm deep x 30mm wide is available, hookless.
Farsports
g32ecs
by g32ecs
EDIT
Build is 1518g according to EIE, website error. Oh I wish it was correct.
szymonef
by szymonef
I have a hard time deciding which rim depth and shape to choose from EIE... Wheels wil be for allround and hilly riding, tires 23-25mm. What do you think?
sfo423
by sfo423
szymonef wrote:
Tue Jan 21, 2020 11:38 am
45mm
musiclover
by musiclover
Why such a narrow tyre choice?
szymonef
by szymonef
Based on experience. I'm now using 23 GP4000SII. Thay are 25 mm in real life on my 25 mm wide rims. So, I assume that going little bit wider rim than 25 would result in even wider tires. That's why I don't want to choose tires wider than 25mm.
