Open mold wide profile carbon wheels
knightskid
by knightskid
rides4beer wrote:
Tue Apr 02, 2019 1:53 pm
knightskid wrote:
Tue Apr 02, 2019 12:15 pm
Looking at Lightbicycle website for this wheel, isn’t it stated is for disc brake based on the title? But you set it up as rim brake.
Yup, they have it listed as a disc brake wheel, but you can get it for rim brake, just let them know when you're placing the order. I also got the grooved graphene brake track for an extra $30, no braking issues at all with Swissstop Black Prince pads.
That was great, it is the grooved graphene brake track that interest me to get from lightbicycle. Too bad farsports doesn't have it because my 1st choice is still with them since i have already bought a tubular rim from them a year ago and still happily riding it.
MAJ
by MAJ
ooo wrote:Yishunbike Mid Hook design looks interesting, weight is a little bit better than Farsports
I tried to order 2pc, but they told me they sell them in bulk (10pc)
https://www.yishunbike.com/700c-asd-roa ... m_p61.html
RDG38C-TLR-DISC
ASD38C-TLR-DISC
€ 539,71 36%OFF | 1259g High End 700C 25mm Outer 18mm Inner Width Tubeless Clincher Road Disc Cyclocross Bike Carbon Wheels Wheelset 24 Holes
https://s.click.aliexpress.com/e/b28EYqZx
Check this wheelset weight!
This is the rim:
€ 140,55 41%OFF | 400g 700c 38mm x 25mm Tubeless Clincher Carbon Bicycle Rims Cyclocross Bike Rim Road Disc CX Wheel No Brake Track 20 24 28 Holes
https://s.click.aliexpress.com/e/cpXHGTyz
ooo
by ooo
400g 700c 38mm x 25mm symmetric is a good offer. I have asymmetric holes 38mm x 25mm rims ~415g (425g advertised)
accuracy of chineese rim weight +-25g, hub weight +-25g, total spoke weight +-25g,
single wheel weight accurary +-75g, wheelset (2 wheels) total weight accuracy +-150g
17-18mm inner is a little outdated, even conservative shimano offer new road wheels at least with 19mm inner
(2019 updated shimano wheels WH-RS171: 19-622, while 2017-2018 wheels WH-RS170 was 17-622)
Pinguin
by Pinguin
knightskid wrote:
Tue Apr 02, 2019 10:52 pm
Farsport also sell this grooved brake track if you ask,but it would be louder than normal and eats brake pads,only better if you ride in rain
knightskid
by knightskid
Pinguin wrote:
Wed Apr 03, 2019 5:46 am
Oh ok...that was great.....have just browsing their rim brake, this one interest me FSL45-CM-28 which is USD334 include free shipping.....https://www.wheelsfar.com/700c-carbon-c ... 60-88.html
MAJ
by MAJ
ooo wrote:400g 700c 38mm x 25mm symmetric is a good offer. I have asymmetric holes 38mm x 25mm rims ~415g (425g advertised)
And what do you prefer; symmetric or asymmetric. This seller offer the major part of rims asymmetric but I don't know about the behavior of the wheels at high speeds with an asymmetric rim...70/80km/h.
On MTB the speed and the aerodynamics is less important, but in road is very important.
Anyway I had readen that asymmetric rims have less impact resistance.
For this reason I am searching for symmetric rims, but may be I'm in wrong direction.
On farwheels I have found following two options but heavier than Deerobust claimed weight:
https://www.wheelsfar.com/35mm-x-28mm-r ... 2-hub.html
https://www.wheelsfar.com/35mm-x-26mm-r ... 2-hub.html
Jugi
by Jugi
Pinguin wrote: Farsport also sell this grooved brake track if you ask,but it would be louder than normal and eats brake pads,only better if you ride in rain
That depends very much on usage. In my regular use, I wear out a set of brake pads in 2-3 years. If go to Mallorca or some place similar, I'll get a considerable amount of wear in a week of hard riding. So brake pad wear is not really a concern in regular use, and I want my brakes to have comparable feel and power in all conditions. For me, a grooved brake track seems like a better option.
Pinguin
by Pinguin
Jugi wrote:
Wed Apr 03, 2019 7:21 am
Thats right
I live in the mountains,so i need a lot of pads
If i had the choice again i would go with the normal brake track
knightskid
by knightskid
Erm....something would like to ask. Am wondering if going for 20 holes for the rear, is asking for trouble for a 77kg rider? 😬
Jugi
by Jugi
In my experience (79kg) going below 24 spokes in rear wheel is asking for trouble. Spoke pattern and bracing angle have some influence in it as well, some combinations work better than others.
Four spokes weigh about 20 g and they change a wheel's ability to handle stress quite considerably.
Beaver
by Beaver
knightskid wrote:
Wed Apr 03, 2019 11:35 am
21 spokes with 2:1 lacing would be better - but those hubs are only availiable from Bitex etc. Maybe Carbon Ti will one day offer this option.
ooo
by ooo
MAJ wrote:
Wed Apr 03, 2019 6:33 am
No need for asymmetric in front, it is only needed on the rear wheel to make left and right spokes have closer tension numbers
For the rear wheel aero penalty is minimal
none
by none
AFAIK, asymmetric rims are used because of disc rotor that offset the hub flange, asymmetric rims allow the same or similar length spokes to be used for disc & non-disc side or drive & non-drive side of the hub flange, for less complicated wheel building.
MAJ
by MAJ
https://www.yishunbike.com/700c-rsd-roa ... s_p62.html
What do you think about these rims.
I think are the rims of Deerobust seller ( Aliexpress)
emotive
by emotive
MAJ wrote:
Wed Apr 03, 2019 10:54 pm
they're only 25 or 26mm wide at the transition from the rim to the tyre. That will be good if you want to run 23mm tyres with a measured width of 25 or 26mm. If you want to run 25mm tyres with a measured width of 27-28mm, then a rim which is wider than 27mm at the transition point is more aerodynamic.
