Open mold wide profile carbon wheels
alexdi
by alexdi
emotive wrote:
Wed Jul 18, 2018 5:42 am
alexdi wrote:
Wed Jul 18, 2018 3:11 am
The rim profile, which looks rather square in photos, is actually nicely rounded.
Well that changes things, their web images with the square profile are costing them sales IMO.
It's difficult to improve the photos, my own look similar. The cross-section schematic of the wheel is accurate.
alexdi
by alexdi
pushstart wrote:
Wed Jul 18, 2018 12:48 pm
@alexdi, how is the angle of the spokes entering from the side opposite the asym offset (ds rear, nds front)? That is my only complaint with my Yishun asym rims: they did not appear to angle the spoke holes, so the spoke angle entering the rim is a bit extreme. And I fear the nipples might break there, though I have not had any issues yet (a couple thousand miles).
Angles look fine to me. They've also got a nice shelf for the tubeless stem.
bilwit
by bilwit
clonefan wrote:
Tue Jul 17, 2018 7:10 pm
How do you like the 46mm LB wheels? If you were buying today would you get the 56mm ones?
I have the "CX36" ones with i9 hubs (love those hubs). Personally 21mm internal/28mm external is plenty wide for me, any more and I'd feel like I'm driving a bus. I intentially got the low profile because it's my rain/weather bike and I go through what can be some horrendously windy bridges and don't care about speed so much as getting tossed around.
For my fast rim brake bike, if I was in the market for ~50-60mm rims I'd probably pick up a deal on last gen Campys (Bora Ones) or perhaps FLO60s. All of which are made for being 25mm wide though (I'm not bothered with uber wide rims)
LeDuke
by LeDuke
Rims and other products are about to get a bit more expensive for us Americans.
Can’t wait...
pushstart
by pushstart
Yeah, those look much better than mine. Maybe the 33mm-deep rims have an issue with spoke hole angles that isn't shared by the molds for the other depths? Anyway, hopefully it won't turn into a reliability issue long-term for me.
kyleFu
by kyleFu
Farsports new Road disc brake rims / wheels.
40mm deep * 30mm wide rim, 410g / pc +/-15, Hookless + Tubeless.
30mm deep * 28mm wide rim, 390g / pc +/-15g, Tubeless.
35mm deep * 28mm wide rim, 410g / pc +/-15g, Tubeless.
45mm deep * 28mm wide rim, 440g / pc +/-15g, Tubeless.
58mm deep * 28mm wide rim, 460g / pc +/-15g, Tubeless.
35mm deep * 26mm wide rim, 400g / pc +/-15g, Tubeless.
45mm deep * 26mm wide rim, 430g / pc +/-15g, Tubeless.
Wider profile + Ultralight
emotive
by emotive
kyleFu wrote:
Mon Jul 23, 2018 3:07 am
What are the inner diameters on these wheels Kyle?
kyleFu
by kyleFu
emotive wrote:
Mon Jul 23, 2018 11:51 am
HI Emotive, inner width?
23mm inner width for 30mm outer width.
21mm inner width for 28mm outer width.
19mm inner width for 26mm outer width.
AJS914
by AJS914
Does anyone have any opinions on the budget priced hubs you might see on Farsports online store? I typically see:
Novatec
Bitex
Ed hub
DT Swiss 350
Powerway
What's the best bang for the buck? Is it worth paying $70 extra for the DT 350. I have a set of those and they have been flawless. I don't want to pay $200 extra for the DT 240S. Weight hardly matters as I'm a flat lander now.
Hexsense
by Hexsense
For road rim brake hub at least,
Bitex and Ed hub have faster rear hub engagement. If i recall correctly, it's 27 POE on Novatec and 48 on Bitex (24t with 2 sets of 3 pawl-- 6 pawl in total, alternately engage between 2 sets). But i'm not sure about the number.
Novatec hub is quieter though. But i still like Bitex more.
Do not buy the lightest option possible unless you are very light. Larger bearing worth extra weight. Use the one that is rebranded to Bikehubstore Super light hub, not the Ultra light hub.
you pay $70 extra for DT350, gain weight, lose POE down to 18 point (unless you spend even more to upgrade the ratchet). At least it supposed to be more durable. But my Bitex and Novatec hub still going strong after years, and a few crashes that broke some spokes too.
If you want DT-Swiss 350, go with Straight pull version. They somehow isn't very heavy.
refthimos
by refthimos
Came across these Deerobust rims. About $1200 built up with Extralite hubs and Sapim Rays. For a tubular rim, they seem to tick all the boxes for a real-world climbing wheel - wide and deep, should pair well with a 25mm tubular, Rule of 105 compliant, 1079g claimed weight. I think I'm going to give them a go.
EVO | 5.37kg
SystemSix | On order
TCR Advanced SL Disc | 7.35kg
P5 | 9070 Di2 | SISL2 SRM | Enve 7.8 | Alto Disc
T1 | P2Max Type S | Rolf Prima FX58/Zipp Super 9 Disc
AJS914
by AJS914
Thanks. How easy is to rebuild Bitex hubs? I found a youtube video on the Novatec and it looked really easy to replace bearings. Searching around, it sounds like Farsport's ED Hub is oem'd by Bitex.
:D
Hexsense wrote:
Wed Jul 25, 2018 7:53 pm
Marin
by Marin
Also easy, drive out the bearing using the axle, and press them back in with a matching socket. Heating the hub shell helps. 10 Minute job for the drive side bearing, which is the one you'll be changing every few 1000k if it's a RAR9.
pushstart
by pushstart
My $0.02 is to avoid Bitex/ED ultralight hubs if you are a bigger/stronger rider. I weigh around 80kg and I could make pawls skip on that hub standing out of the saddle on very steep hills.
I definitely don't recommend any of the Bitex disc hubs either if you are similarly sized.
I think I had decent experience with Bitex SL hubs, though (not UL). They obviously weigh more, though.
I don't have any experience with Novatec road hubs, but a fair bit of experience with their disc hubs. They work fine; they skip every now and then on me, but seem to hold up. But I think you kinda get what you're paying for here. I always replace the bearings in cheap Novatec hubs with Enduro or something stainless -- or buy the hubs from BDOP with EZO bearings.
Personally I would pay the extra for DT Swiss. For a road hub POE is basically irrelevant anyway.
romanmoser
by romanmoser
Hey guys . It's a bit long sorry :)
(Moderators note) Edit: Post it in one thread, that's enough.
