Open mold wide profile carbon wheels
benp
by benp
Just the angle. My picture with the ruler was just for the brake track width.
I've just take my verniers (manual) to the rim and they are bang on 46 (28x21)
Hexsense
by Hexsense
So they are widest at the brake track not somewhere in the middle huh?
That is exactly what i wanted.
But i don't need anything less than 50mm so i'll wait until they release something this wide in 50-58mm range.
BTW: is the inner edge curve between side wall to where spoke hole and valve hole reside quite smooth? it looks quite blunt in the picture.
tharmor
by tharmor
petepeterson wrote:$1200usd.....
http://m.dengfubikes.com/index.php?s=/181.html
tharmor
by tharmor
^Wouldn't want to be the guinee pig on these but that's about 1/4 the cost of some Lightweights. Probably 1/4 the performance as well.
LeDuke
by LeDuke
tharmor wrote:^Wouldn't want to be the guinee pig on these but that's about 1/4 the cost of some Lightweights. Probably 1/4 the performance as well.
How would you objectively rate that?
Kind of an absurd statement. Like saying Chinese tubulars offer 1/4 the benefits of a $2,000 set of tubs. I'm guessing probably closer to 95%>
Sent from my XT1585 using Tapatalk
romalor
by romalor
they are nice but not tubeless ready big fail ...
I asked for the rim weight but no informations , the hubs are light tough
Inside width: 17,5 mm a bite conservative
outside width: 24 mm
I think Munich Composites are some of the earliest believers in filament wind rims with Velocite and theirs VENN rims
JLS
by JLS
Can anyone recommend me some good light carbon clincher rims for extralite cyber sp hubs.
So far i cant decide between.
https://www.lightbicycle.com/Carbon-700 ... rface.html
http://www.nextie.net/new-road-clincher-NXT32RC
Any other recomendations?
Marin
by Marin
I have the LB ones in 25 and 35mm and like them a lot.
However, for Cyber SP hubs you have to use high-end rims, especially since the current 25mm wide rims aren't all that light.
Schmolke?
JLS
by JLS
Marin wrote:I have the LB ones in 25 and 35mm and like them a lot.
Schmolke?
How are the rims with Cyber SL hubs?
Marin
by Marin
Sorry, I meant that if I spent $$$ on the lightest, craziest hubs available, I'd do the same for rims. The LB and Nextie are more the reasonable choice, and will of course work just fine. I ride mine with Bitex and Novatec hubs.
JLS
by JLS
Marin wrote:Sorry, I meant that if I spent $$$ on the lightest, craziest hubs available, I'd do the same for rims. The LB and Nextie are more the reasonable choice, and will of course work just fine. I ride mine with Bitex and Novatec hubs.
Yer i was thinking of that but the difference in weight for rims is not that big so i thought it would be better spent elsewhere like a decent saddle.
petepeterson
by petepeterson
Wonder how stiff those dengfu LW's are....
CallumRD1
by CallumRD1
Does anyone have any experience with the Light Bicycles 36mm or 46mm deep, 28mm external, 21mm internal width clinchers? I'm looking at building up a pair of the 46mm clinchers in disk format for my Felt F3X cross bike that gets used for everything from road rides to gravel rides. It seems like the perfect rim for 28c road tires and 33c cross tires.
Additionally, does anyone have any experience with the hookless bead that they offer? They claim that it will drop 10-15g from the rim weight, be a stronger construction, and be less susceptible to pinch flats. I like the sound of it (I ride my 28c tires at 60-70psi and they say the max is 80psi) but I'm a little nervous having never encountered hookless road rims before.
For reference, I'm a 6'2" 150 pound guy.
fabriciom
by fabriciom
Why is it that I can not find Chinese 80mm tubular rims with out dimples...
kulivontot
by kulivontot
Have you tried searching for 88mm rims?
