Moots Vamoots RSL - 6140g
elfuinha
by elfuinha
elfuinha wrote:Tomorrow hopping to put this in the bike Image
Enviado do meu C6903 através de Tapatalk
In 52/36
Will add about 72g (+ or -)
elfuinha
by elfuinha
Image<br />Put mine one hour ago, just ride home from the shop. I did fill the difference in stiffness from my previous setup.<br /><br />First time take about 1h30 to mount the crank.<br /><br />Will ride on Saturday, and give initial feedback of it.<br /><br />Note: front derraileur needs to be a little higher - thanks for that note.
elfuinha
by elfuinha
Inicial report is very good...<br />The stiffess of the crankset, is very high compared to the Previous Setup that I had the THM CLAVICULA with Carbon-ti chainrings. No noises what so ever, but I've put many km in it. The front derraileur really needs to be a little higher, to work flawless... The passages on the front are very fast and direct... Strangely need to check my Cleats, because some pain started to appear on the plant of my feet bought, maybe to the stiffess of the package is causing this... Still don't know, will change shoes and try again.<br />Standing up the stiffess is very high, no noises what so ever either... I began to think that the previous noise that I had on the bike when standing came from the bending of the chainrings on the THM CLAVICULA, rubbing the front... This didn't happen with the OMC.<br /><br />Loving it so far.<br /><br />Enviado do meu C6903 através de Tapatalk
elfuinha
by elfuinha
New saddle for longer distances - not so weight weenie...
:thumbup:
lowlands
by lowlands
Wow, great rig you have!!!
elfuinha
by elfuinha
Thanks Lowlands
elfuinha
by elfuinha
The final component that was missing - OMC PFBB30
kolarzyk
by kolarzyk
Stunning bike!
elfuinha
by elfuinha
kolarzyk wrote:Stunning bike!
many thanks
LouisN
by LouisN
Wow !! Total looker :beerchug: !!!
Love it !
Louis :)
elfuinha
by elfuinha
Doing some changes, this year:
1st - New saddle - Berk Lupina 150mm padded (ordered)
2nd - Selling the bar stem
3rd - MCFK stem 110mm 6º again (manage to get the last one i've seen in 110mm 6º 3K - MCFK no longer does 3K wave finish :( (ordered)
4st - MCFK handlebar 42cm UD only now :( - so it will be equal in measures to my Victoir Cycles (after selling the BarStem Combo)
5ft - Vittoria control 25mm tubular if they fit the Fork
6st - Specialized SWORKS 175mm Crank + Dzero Quarq + Absolute Black (when $$$ is available)
bilwit
by bilwit
the absolute black rings are pretty heavy, no?
elfuinha
by elfuinha
bilwit wrote:
Thu Jan 25, 2018 8:18 pm
A little nothing special... if it works... I don't mind a some more grams...
elfuinha
by elfuinha
elfuinha wrote:
Thu Jan 25, 2018 3:49 pm
4st - MCFK handlebar 42cm UD only now :( - so it will be equal in measures to my Victoire Cycles (after selling the BarStem Combo)
1st - New saddle - Berk Lupina 150mm padded - on the way
3rd - MCFK stem 110mm 6º - on the way
Anyone with experience on these Handlebars:
- Schmolke compact handlebar
- Haero Carbon H.145 RR SL
- Bikeahead Roadhandlebar
