Metal guy does a plastic bike (Dogma F)
Introduce your new bike! Introduce yourself! Use metric.
CustomMetal
by CustomMetal
OtterSpace wrote:
Wed Sep 18, 2024 11:32 pm
too bad gemini only goes up to 46T it would go great with this build.
I know! I could go garbaruk, might do in time but already had this chainring in my parts draw so will do for now
Allegra- Steel Lugs ?.?kg
Alya- Ti Climbing 7.8kg
Belladonna - Carbon Aero 7.05kg
Bertha- TT 9.8kg
Bianca- Ti Gravel 8.9kg/?kg (road/gravel)
Perdita- Ti Turbo bike 8kg
Verity- Ti Race 8.2kg
CustomMetal
by CustomMetal
Frame (with FD and RD mounts)
Fork - uncut. Will be cut quite a bit as running slammed
Bertha- TT 9.8kg
CustomMetal
by CustomMetal
Seatpost
Handlebar
Thru axels
Bertha- TT 9.8kg
CustomMetal
by CustomMetal
Rotor lock ring
Expander/top cap/carbon ti bolt
Frame small parts
Aero go pro mount
Bertha- TT 9.8kg
CustomMetal
by CustomMetal
29mm 111 tyre
Bertha- TT 9.8kg
rollinslow
by rollinslow
Looks like it's going to be a sweet build. That color is great.
I see all the "Campy spoken here" signs posted in the shop.......not too late to give in or change to "sram spoken here" :D
CustomMetal
by CustomMetal
rollinslow wrote:
Wed Oct 16, 2024 6:15 pm
Ha ha, I have zero interest in WRL as I don't like the aesthetics and for 1x SRAM is king. I do love Campy but only their mechanical rim brake stuff. Have a steel lugged bike coming with Campy on. 5 of my bikes are SRAM but have a dura ace and campy bike just to keep me honest.
I am thinking 6.8kg with power pedals might be possible which for a 575 would be good
Bertha- TT 9.8kg
rollinslow
by rollinslow
That would be a really nice weight for a Dogma. The 1x will certainly help you get there. Yeah, with 1x it's an easy choice to go Red. About time we had a top spec new Dogma on here!
jadedaid
by jadedaid
Looking forward to seeing how this one turns out and how you like it compared to your metal bikes. Always happy to see road bikes built up as 1x, I'm a fan myself and interested to see how the Dogma looks with that setup.
CustomMetal
by CustomMetal
Weight for cranks, cut steer, the links we took off the chain. Also fitted an aerocoach chain catch but removed the cheap looking sticker
Bertha- TT 9.8kg
CustomMetal
by CustomMetal
Weights with cages and garmin mount but with and without pedals
Bertha- TT 9.8kg
CustomMetal
by CustomMetal
Initial pic from when the build was finished, but should have some better ones soon. Aim to get the frist ride in today if time
Bertha- TT 9.8kg
CustomMetal
by CustomMetal
pre build layout
Bertha- TT 9.8kg
CustomMetal
by CustomMetal
Trying to pre-order a gemini 50 tooth chain ring, which along with my climbing wheels should bring the full build weight down to under 6.8kg.
The climbing wheels are Strada's new 40/45s which are 40 deep front, 25 internal, 34.5 external, hooked, non plus hubs, carbon spokes, 45 deep rear, 21.7 internal, 29.5 external, hooked, non plus hubs, carbon spokes. Should be around 1120g. plus they will have 28mm gp 5000 strs so over all easily 150g lighter maybe as much as 200g.
The new chainring should be arond 100g lighter than the Sram one.
The only other things are I am waiting for Ceramic Speed to do a new SLDT headset for the new Dogma F and Silca to do a new Sram RD hanger. These probably won't save any weight but will add to the package and reduce maintenance.
I seriously thougth about a Darimo post but would only save me around 70g and I would loose the colour matched seatpost which looks soooo good on this frame so not bothering with that. Other than that I should be all done
Bertha- TT 9.8kg
MrCurrieinahurry
by MrCurrieinahurry
Think you need to add this beauty to your signature mate... What a bike 💥
