Metal guy does a plastic bike (Dogma F)
Introduce your new bike! Introduce yourself! Use metric.
CustomMetal
by CustomMetal
So I have finally ordered my first non custom road bike since 2014 and first non metal (Not counting the TT bike).
I had a Spoon Vars on order but that got canceled when their supply chain got effected last year and instead got my 4th Sturdy which I was actually very relieaved about as the Sturdy Fidah was a much better fit for what I wanted. However my Saffron got written off a few months ago and as a knee jerk reaction I ordered a Prova Intergrale to replace it. However when I actually thought about the bikes i have (Sturdy Sidhe (race), Sturdy Fidah (climbing/endurance), Sturdy Cilla Mk2 (gravel), Sturdy Keela (vintage steel), Burls road bike (these days turbo bike) I realised the prova wouldn't give me anything new and I already had peak custom Ti. I also prefer Ti to steel so didn't want to get another steel bike.
So I thought maybe it was about time I bought another world tour bike and I wanted to see what peak carbon and aero was like these days. I am alergic to spacers so needed a bike I could run slammed. I also wanted a bike that I could tell what it was from its silouet and didn't just like every other carbon aero bike. Finally I wanted something that handeled like it was reading my thoughts. This pretty much left me with the Dogma F. After riding a mates Dogma F from 2023 I knew it was the right bike so I have ordered the new 2024 version.
This will be a full build thread with weights and pics when everything lands. I have entrusted the build to my not local but wholly worth driving to LBS Ride 24/7 in Cirencester. I would highly recommend them to anyone! The fact that I drive 45 mins past many other bike shops should speak s to how highly I rate them. here is what it will consist of:
Frame - Dogma F 2024 575 (with FD and RD mounts) - 1080g
Fork - Dogma F 2024 (cut) - 411g
Seatpost - Dogma F 2024 - 181g
bar/stem - Most Talon Ultra Fast, 36/42cm, 120mm - 296g
Spacers - N/A :twisted:
Top cap bolt - Carbon Ti - 2g
Expander & topcap - pinarello - 32g
headset - pinarello or ceramic speed - forgot to weigh but will upgrade to Ceramic speed when released
thru axels - pinarello x2 - 54g
Bottle Cages - Tune x2 with 4x carbon ti bolts - 33g
Rotor Lock ring - Absolute Black - 6g each
Rotors - Galfer 160 x2 - 190g
Bottom Bracket - Ceramic Speed ITA - 85g
Crankset preload - Ceramic Speed - 16g (inc spacers I may not need)
Shifters and calipers - Sram Red E1 x2 - 712g
Rear Derailuer - Sram Red e1 - 261g (with origional cage)
battery - sram x1 - 24g
OSPW - Ceramic Speed RS Alpha - 105g
Cassette - Sram Red 10/36 - 233g
Chain - Sram Red E1 - 259g (uncut and before waxing)
Crankset - Sram Red DUB E1 170mm - 306g
Chainring - Sram Red 50 tooth 1x - 221g (will upgrade to a Gemini 50 tooth when its made. Should drop over 100g)
Pedals - Garmin Rally RS200 - 318g
Bar tape - Burgh - 55g
Bar Ends - lucendi Ti (Cerakoted Black) - 7g
alternate bar ends - schmolke - 3g
Garmin mount - Framesandgear dogma with aero gopro - 30+11g
Saddle - Bjorn Sedlo 143 - 92g
Wheels - Strada 55/60 (strada 55/60 rims, Tactic Hubs, Carbon spokes) - 1248g
Tyre - GP5000 str 30mm - 308g
Tyre - 111 29mm - 274g
Total - 6.73KG with out pedals but with cages and garmin mount. 7.05kg with pedals.
With Climbing wheels (40/45 stradas which should be 1120g and the gemini chainring should get below 6.8kg
Allegra- Steel Lugs ?.?kg
Alya- Ti Climbing 7.8kg
Belladonna - Carbon Aero 7.05kg
Bertha- TT 9.8kg
Bianca- Ti Gravel 8.9kg/?kg (road/gravel)
Perdita- Ti Turbo bike 8kg
Verity- Ti Race 8.2kg
robeambro
by robeambro
CustomMetal wrote:
Tue Sep 17, 2024 1:25 pm
This will be a full build thread with weights and pics when everything lands but hear is what it will consist of:
Frame - Dogma F 2024 575 - ?g
Fork - Dogma F 2024 - ?g
Seatpost - Dogma F 2024 - ?g
bar/stem - Most Talon Ultra Fast, 36/42cm, 120mm - ?g
RD hanger - Dogma F - ?g
Top cap - Most - ?g
Expander - pinarello or carbon ti -tbc
headset - pinarello - ?g
thru axels - pinarello x2 - ?g
Bottle Cages - Tune x2 - ?g
Bottle Cage bolts - Carbon ti x4 - ?g
Rotor Lock ring - Absolute Black - ?g
Rotors - Galfer 160 x2 - ?g
Bottom Bracket - Ceramic Speed ITA - ?g
Crankset preload - Ceramic Speed - ?g
Shifters and calipers - Sram Red E1 - ?g
Rear Derailuer - Sram Red e1 - ?g
OSPW - Ceramic Speed RS Alpha - ?g
Cassette - Sram Red 10/36 - ?g
Chain - Sram Red E1 - ?g
Crankset - Sram Red DUB E1 170mm - ?g
Chainring - Sram Red 50 tooth 1x - ?g
Pedals - Garmin Rally RS200 - ?g
Bar tape - Burgh - ?g
Bar Ends - lucendi Ti (Cerakoted Black) - ?g
Garmin mount - Framesandgear dogma with aero gopro - ?g
Saddle - Bjorn Sedlo 143 - ?g
Tyres - GP5000 str 30mm - ?g
Total - ?KG
Looking forward to the pictures.
Out of curiosity, whereabouts do you live? I am also based in the UK and can't think of many places where I'd want 50-36 as my easiest gear. Then of course you will have had your reasons for choosing this setup.
CustomMetal
by CustomMetal
[/quote]
[/quote]
I live in the middle of the North Wessex Downs near Marlborough and Newbury and we have climbs up to 17% around here. However my Sturdy race bike is 1x 50-10/33 and I can get up everything and have used it on 5-6 hour rides so this will be even easier. I started riding road bikes in 2010 where one of the first rides I did was a solo John O'Groats to Lands end which I did on 25mm tyres, panieers and a 53/39-11/25 so a 50-33 which is the equivalent to 38/25 is no problem and a 50-36 is 39/28 so even easier :D
however my climbing sturdy has 50/34-11/34 when I want to go to Europe or for endurace Ultras
Bertha- TT 9.8kg
robeambro
by robeambro
CustomMetal wrote:
Tue Sep 17, 2024 1:58 pm
[/quote]
[/quote]
Thank you - to each their own, I wouldn't mind having "tougher gearing" for Europe (longer climbs, shallower gradients) but could do with easier gearing for UK (shorter climbs, crazy gradients). :D
CustomMetal
by CustomMetal
robeambro wrote:
Tue Sep 17, 2024 2:05 pm
[/quote]
[/quote]
Where are you based?
Bertha- TT 9.8kg
robeambro
by robeambro
CustomMetal wrote:
Tue Sep 17, 2024 2:22 pm
[/quote]
[/quote]
Up until now in Scotland. But I'll also specify that I'm probably much less fit than you are (I think I must be around 3.5w/kg FTP these days), so that would also explain a lot as to why I wouldn't run the same gearing..
CustomMetal
by CustomMetal
Bertha- TT 9.8kg
CustomMetal
by CustomMetal
Rotors and bar ends
Bertha- TT 9.8kg
OtterSpace
by OtterSpace
Looking forward to seeing how this build settles. You always learn the best things from people stepping outside their typical preferences.
If you are waxing it might be interesting to try a YBN MK120 in rotation too.
Also looking forward to seeing more details on the ceramic speed preloader ring. I've run the EE many times and like it and just keep going for it as its lighter from what I could dig up but the ceramic speed does look a lot smoother and therefore nicer in my book.
CustomMetal
by CustomMetal
Thanks OtterSpace. I might try a YBN on my dura ace bike but I only run sram chains on my sram bikes for shifting and durability. However it will be my first strip chip chain which will be interesting
Bertha- TT 9.8kg
CustomMetal
by CustomMetal
Saddle, RD, OSPW, Chain
Bertha- TT 9.8kg
CustomMetal
by CustomMetal
chainring, cassette, shifters and calipers
Bertha- TT 9.8kg
CustomMetal
by CustomMetal
bottle cages, BB, preload ring, top cap bolt, schmolke bar ends and rd battery
Bertha- TT 9.8kg
CustomMetal
by CustomMetal
bar tape
Bertha- TT 9.8kg
