1st Gen Supersix Evo build
Introduce your new bike! Introduce yourself! Use metric.
tomsneo
by tomsneo
Greetings fellow Weight weenies!
Last year I picked up one of my dream frames a Black INC Supersix evo nano,
I was really excited to build this frame but unfortunately due to it being too big for me being a size 56 I had to let her go. I was bummed out because I always wanted that frame colorway but I'd rather be safe than sorry, I sold it to a good friend of mine who made it his dream build.
So that brings me back to finding another frame, Since I could'nt find a supersix evo black INC in my size I decidied to ditch that idea and I picked up a team edition frame only no fork in a 54 that needed carbon repair for $180 on FB Marketplace.
This is the damage
I was able to source a fork through my LBS since they are a cannondale dealer they had a few parts in thier archive.
So now finally having a frame to build the plan was to have all the paint stripped off the frame completley. I sent out my frame to a local friend who specializes in carbon frame repair he also fixed the Black INC frame I had pruchased prior. He was able to inspect the frame thoroughley and fixed the crack above the rear triangle. I chose to not run red etap because I want to keep this frame mechanical for now, My friend asked me if I wanted to shave off the cable guide you can see some of the raw carbon in this pic.
I will have more detailed pictures of the frameset and weights later this week.
Parts for the build so far
Sram Red 22 10speed with 11 speed shifters
Sram Red 170mm Crank arms
Carbon TI chainrings
Cane Creek EE brakes
Jagwire Cables
berk lupina short nose saddle
Wheelset Winspace Hyper R33
Tires Conti GP5000
I'm still undecided on what finishing kit Im going to run any suggestions would be great!
cheers till next time!
Masi 3VC SL
S-Works SL7
Supersix Evo HM Black INC
Giant Propel Advanced Pro 0
tomsneo
by tomsneo
Finally got my frame back from paint, That's right paint! The shop that did my carbon repair did a horrible job clear coating and wet sanding the frame. I was extremely upset with the finish and decided to take it to my friend who paints my cars, We decided to add candy black in the clear coat to make it look less brown and used a special 3 stage high gloss clear coat.
Carbon repair shop's clear coat absolute trash! The carbon repair was done well at least. If you look closely in the picture below you can see how they did'nt even clear certain spots you can also see how the carbon looked very brown.
Now compared to my friends work
Now the build has finally begun! I stripped my masi rim brake and swapped over all the parts from that previous build.
Masi 3VC SL
S-Works SL7
tomsneo
by tomsneo
Masi 3VC SL
S-Works SL7
mrjetlee
by mrjetlee
tomsneo wrote:
Sun Sep 01, 2024 1:01 pm
This finish looks amazing! I would love to do something similar to my bike one day, but that's after I finish everything else on it first. Paint job is the last thing I want to do on it.
Did you weigh the frameset before and after you took stripped the paint off? Wondering if you managed to lose some weight by stripping the paint 🤔
Lovely build! 6.45kg is a very respectable weight. Looks like you can easily save some weight at the stem and cranks, but it looks amazing as it is.
tomsneo
by tomsneo
mrjetlee wrote:
Thu Sep 05, 2024 11:36 am
Thank you,
Unfortunately I did'nt get to weigh it after but I went a lil heavy on the clear coat because I wanted it to be as glossy as possible. I have a set of hallowgram cranks arriving today but i did order a set of carbon ti chainrings as well for my Dura ace cranks wont see those till November.
Masi 3VC SL
S-Works SL7
tomsneo
by tomsneo
Took the bike out for the first time this thing is awesome! its stiff but smooth, Extremely good on climbs. I should have my new cranks here today cant wait to throw those on! few pics from today.
Frame
2016 Cannondale Supersix Evo Hi-Mod size 54
Custom painted Candy Black/Raw carbon
Finishing Kit
Enve K-Edge computer mount
Enve road carbon handlebar size 42
Enve road carbon stem size 90
Enve road cadrbon seatpost 0 setback size 400
Saddle
Berk Lupina
Bottom Bracket
Wheels Manufacturing PF30
Groupset
Dura-Ace 9100
Cables
Jagwire
Brakes
Canecreek EE Brakes
Chain
KMC K11 Gold waxed
Crankset
Shimano Dura-Ace crank arms 170mm
Carbon TI 50/34T chainrings
Absolute Black chainring bolt covers
Wheelset/Tires
Winspace Hyper R33
Continental GP5000 TDF size 25
Bottle Cages
Alpitude Components Superleggero
Bartape
LizardSkinz DSP 1.0
Masi 3VC SL
S-Works SL7
mrjetlee
by mrjetlee
I'm here again to say, wow this looks absolutely stunning 😍 can't wait to see it with the new cranks on! I'm interested to see how much weight you'll save. I'm about to put sisl crankset on my supersix today too!
tomsneo
by tomsneo
mrjetlee wrote:
Sat Sep 07, 2024 7:02 pm
Thank you! I will weigh it hopefully this week. Post a pic of your's I’d love to see it cheers!
Masi 3VC SL
S-Works SL7
tomsneo
by tomsneo
I picked up a hollowgram crankset last week to try it out before I buy set of SL2 crank arms, My original plan was to swap chainring on my DA9100 cranks to Carbon TI. Unfortunately wait times on anything from Carbon TI is almost a year away.
I got really lucky and picked up a set yesterday dreams do come true :beerchug:
Masi 3VC SL
S-Works SL7
tomsneo
by tomsneo
Absolute Black bolt covers for DA9100
Masi 3VC SL
S-Works SL7
iamraymond
by iamraymond
IMO, the SI crankset is better suited to your Supersix. It's also it's lighter than the DA setup.
The Carbon TI rings may be bling, but they are the same weight as the DA rings and you'll loose the perfect Shimano shifting.
tomsneo
by tomsneo
Installed new Decals and chainrings Installed It's my 3rd set of carbon ti chainrings I have them on two of my other bikes never had an issue shifting so far so good. Really loving how the bike looks now, I have a few other changes ahead to lose a few more grams but for now I’m content.
Masi 3VC SL
S-Works SL7
tomsneo
by tomsneo
Finally picked up a set of 3.4’s pics dont do them justice but they are mint! Got them from a fellow patron at my lbs. wheels come with enve carbon hubs with ceramic bearings I already ordered the factory black decals tubeless valvestems and titanium skewers. Image
Masi 3VC SL
S-Works SL7
tomsneo
by tomsneo
Recently cut my steerer tube and installed latex tubes on my hypers current weight.
Masi 3VC SL
S-Works SL7
Alfonso
by Alfonso
Hello
I am following your notation because I am making a bicycle with the same characteristics as yours. At the moment I have removed the paint from the frame and fork and then I will assemble the light components that I have.
I am closely following the evaluation of your bicycle.
all the best
