First sub5 Orbea Orca '24 - 4,835kg
You mention hypercap for the top cap but it looks like you have a carbon top cap with hyper bolt. What is the concave top cap you’re using?Sportastic wrote:All the screws are lightest possiblegabriiaia7273 wrote: ↑Mon Jul 22, 2024 11:42 amTry looking at the Ti-Parts Titanium catalogue. They have a variety of screws and bolts. Also ready-made kits for the various groups
Inviato dal mio SM-A525F utilizzando Tapatalk
ALUMINUM
-extralite 12.1 for bottle cages and FD hanger
-extralite 12.2 for pulley wheels and FD
-extralite hypercap for headset
-ashima for rotors
-oem RD direct mount
-oem caliper pads retainers
-FD/RD limit screws
-carbon-ti chainrings bolts
-custom levers nuts
TITANIUM
-oem darimo for seatpost and stem
-oem clavicula left crank
-titaniumplanet brake hoses nuts
-titaniumplanet drilled calipers bolts
-- Factor Ostro VAM gen2 Disc
-- Specialized Aethos Disc
-- Guru Praemio R Disc
-- Factor LS Disc
-- Factor LS Disc
Porte cap sandedkode54 wrote: ↑Tue Jul 23, 2024 2:24 pmYou mention hypercap for the top cap but it looks like you have a carbon top cap with hyper bolt. What is the concave top cap you’re using?Sportastic wrote:All the screws are lightest possiblegabriiaia7273 wrote: ↑Mon Jul 22, 2024 11:42 amTry looking at the Ti-Parts Titanium catalogue. They have a variety of screws and bolts. Also ready-made kits for the various groups
ALUMINUM
-ashima for rotors
-FD/RD limit screws
-custom levers nuts
TITANIUM
https://r2-bike.com/PORTE-Ahead-Cap-Topcap-UD-Carbon
- wheelbuilder
Absolutely fabulous details. Chapeau
how come your seatpost is so light? did you cut it
That's not cut... if anything it's heavier by 3g from what Darimo quote in 27.2mm, 250mm long;
http://darimo.eu/en/darimo-t1-seatpost
I've made a spreadsheet detailing the weight differences from a stock orbea to this build, mainly because I'd like to see which parts saved a lot of weight (spoiler: it's all of them). It looks like a sore with certain system weights having to have it's own column; I couldn't source info for smaller parts of the stock build. If anyone could make the spreadsheet tidier, it would be greatly appreciated.
https://docs.google.com/spreadsheets/d/ ... sp=sharing
- BernieMoves
- Contact:
Thank you, that is a very interesting and deep insight into what you did. Good basis to pick and choose for my own optimizations. May I make a copy of the sheet?
go for it, I think you can do it from the "file" drop down menu on the upper left cornerBernieMoves wrote: ↑Fri Oct 18, 2024 6:25 amThank you, that is a very interesting and deep insight into what you did. Good basis to pick and choose for my own optimizations. May I make a copy of the sheet?
- BernieMoves
- Contact:
