First sub5 Orbea Orca '24 - 4,835kg
Hi! New here
I am doing an updated build of my previous orca MY23 (5.8kg) on the new MY24 to leave it below 5 fully functional.
I will update with photos and details since it has several modifications made
Frame: Orbea Orca MY24 s51
Fork: Orbea Orca MY24
hanger: Orbea Orca MY24
Headset: CS coated 52x40
Seatpost: Darimo t1 loop ud matt 250mm
Seat: Gelu k4
Bar: Darimo ellipse 3k matt 400mm
Stem: Darimo ix2 ud matt 110mm
Bartape: Deda traforato/lucendi
Bottle cages and hardware: Tune 2.0/extralite
Cables: di2
Brake hoses: Trickstuff beta
Brakes: R9270/amp
Front derailleur: R9250/extralite
Rear derailleur: R9250
Crankset: THM clavicula 170mm
Bottom Bracket: CS coated 386
Chainrings: Carbon ti 50/34
Chainring bolts: Carbon ti
Chain: SUMC sx12sl
Shifters: R9270/schmolke
Cassette: Recon Al 11-28
Hubs: Extralite spd3 ltd edition/CS coated
Spokes: Deerobust carbon
Rims: Deerobust 26x30 hookless
Tires: Veloflex record 25 tlr
Pedals: R9100
Polar/garmin/computer mounts: Darimo
Tape/glue: Dt swiss
Seat: Gelu k4
Cables: di2
Brakes: R9270/amp
Chain: SUMC sx12sl
Pedals: R9100
Tape/glue: Dt swiss
Curently own 2022 Orca, really curious about your 5.8kg bike. Following this topic.
His: Orbea Orca OMX
I love the aesthetics of these framesets, looking forward to the build finish.
Some weights..
Very maticulious build for every element you really know your stuff and did your research. This is really next level.
Any thoughts on Trickstuff beta vs standard Shimano BH90? I know its a bit lighter per meter from R2 claims but curious about stiffness ID and how easy it is to kink and any other standout differences.
Also would love to see more info on the battery mod. Did you get a different cell or just reshell?
Lighter, more "malleable" but because of the Kevlar I understand that it will withstand more pressure than the BH90. As for connectors, the Shimano insert without problems. First time using it but plug&playOtterSpace wrote: ↑Wed Jun 26, 2024 6:34 pmVery maticulious build for every element you really know your stuff and did your research. This is really next level.
battery only reshell, if I to need to save more weight, change the hub connector and cells of course
Looked through the thread and full well could have glanced right over it but what size is the frame? Looks middle of the road is it a 53 or a 55? Really impressed to see it actually on the scale at 725. Definitely swaying me towards this bike even if I'll be on a big boy 57Sportastic wrote: ↑Mon Jun 24, 2024 11:45 amI just came from the bikefitting for order stem and seatpost. Finally ix2 110mm, ellipse 400mm and t1 loop 250mm. Long wait for drag
Short arms and legd, big chest. It's a 51panske525 wrote: ↑Wed Jul 03, 2024 2:24 pmLooked through the thread and full well could have glanced right over it but what size is the frame? Looks middle of the road is it a 53 or a 55? Really impressed to see it actually on the scale at 725. Definitely swaying me towards this bike even if I'll be on a big boy 57Sportastic wrote: ↑Mon Jun 24, 2024 11:45 amI just came from the bikefitting for order stem and seatpost. Finally ix2 110mm, ellipse 400mm and t1 loop 250mm. Long wait for drag
Orbea says 750 for 53 so you can expect increases of 25 more or less through the sizes
