S-Works SL8 - Build (Never!) Finished - 5.94Kg
Introduce your new bike! Introduce yourself! Use metric.
justinfoxphotos
by justinfoxphotos
Hey Steve, just went through your entire thread from start to end as I sit here waiting for my SL8 to get built up and delivered (thanks for sharing!).
I'm trying not to buy anything until the bike gets to me, but I did find some custom ordered white Overfast Thru-Axles here:
https://www.bespokecycling.com/shop/pro ... thru-axles
The only thing stopping me from considering these were the yellow text, and these being white would REALLY suit my frame.
I added them to the cart, but then thought I'd check out your thread as I remembered that you got them, and man... for the minimal weight savings I just couldn't check out.
I think, for now I'll just wait till I get the bike, and just ride it. I had so much fun getting my inner weight weenie on with my SL6. I'm just not sure I want to do the same with my SL8 (yet!).
But again, just here to say thanks for taking the time to document your build. It's given me food for thought.
CustomMetal
by CustomMetal
wheelbuilder wrote:
Tue Nov 26, 2024 3:34 am
stevec1975 wrote:
wheelbuilder wrote:
Sat Nov 23, 2024 3:53 am
Great build but please don't encourage counterfeit stuff. Just don't post about it if you think it has benefits. Works for everyone.
I much prefer giving opinions based on experience, just don’t read about it if you think it has no benefits
Interesting. By that logic, the title of your thread would have to read "counterfeit content" for me to pass over it. My suggestion seems much easier. Post your build but just omit discussing the single counterfeit component. You know.....works for everyone.
This please! We don't want to give counterfeit products any airtime on the forum please
Allegra- Steel Lugs ?.?kg
Alya- Ti Climbing 7.8kg
Belladonna - Carbon Aero 7.05kg
Bertha- TT 9.8kg
Bianca- Ti Gravel 8.9kg/?kg (road/gravel)
Perdita- Ti Turbo bike 8kg
Verity- Ti Race 8.2kg
stevec1975
by stevec1975
justinfoxphotos wrote:
Tue Nov 26, 2024 7:49 am
Hey Justin, glad the thread is of some use, looking forward to what you do with yours. Love the colourway.
Re: Overfast, they do the Axles in 7 colours, they are expensive bling, and nothing wrong with that, many other places to save weight before this obviously.
Screenshot 2024-11-26 102937.png (77.45 KiB) Viewed 1304 times
S-Works SL8 - 6.19Kg/13.71Ib
Cervelo S3 Disc - 6.78Kg/14.94Ib
Scott Addict RC - 6.92Kg/15.25Ib
OnOne - Free Ranger - 8.68Kg/19.1Ib
Scott CR1 - 5.69Kg/12.54Ib
justinfoxphotos
by justinfoxphotos
Oh that's awesome! I had no idea they came in so many colours.
stevec1975
by stevec1975
Update on the Ryet Saddle, been using it on the Turbo quite a lot, and when sitting down for extended periods, it gives me a numb bum!.. back to the trusty Berk Lupina for now.
Still, good to try these things out, saved a fortune on the experiment, as a bonus, I managed to sell it for more that I paid, so an arbitrage opportunity is out there..
stevec1975
by stevec1975
So, thought I would try out the Alptitude Gardena saddle I picked up in the BF sale, looks extremely well made! (And yes, it’s an original!)
MrCurrieinahurry
by MrCurrieinahurry
Ah nice work man! I was interested in these when looking at full carbon saddles as the bulld quality looked better than some other offerings.. let us know how you find it compared especially to the berk as I'm sure quite a few people on here (relatively speaking) have ridden a berk at some point.
stevec1975
by stevec1975
Will do MrCurry, it might be a while, with the crap weather until March..
In other news, finally got round to sanding/polishing my Sram Red E1 165mm Cranks, also a mini tutorial for those who want to try the same.
• Grab 320, 600, 800 and 1200 grades of wet and dry sandpaper and a bowl of water
• Grab a Newspaper to do it on (it will get messy)
• Remove the Dub Cap/Bolt with a Park Tool SPA-2 Pin spanner (remember it's a LH Thread)
• Grap some Sonax Profiline perfectfinish (or you can use T-Cut to be fair)
• Cut Gaffer tape to size to cover the Pedal Threads both sides, the hole for the Dub Bolt, the thread for the adjusting ring etc.
i.e.
Progress through the grades of Sandpaper, ensuring you keep them wet to avoid clogging
320 - Use until it removes majority of Logo's, you should only see clear or white liquid coming off (i.e. the clearcoat or logo)
600 - Use until remainder of logo has gone and is an even surface all round, majority of sanding marks should also go
800 - Use until all sanding marks are gone and it's a nice flat surface.
1200 - Use as a polishing level, very little sanding is going on with this grade
This is at 600
Once finished with the sanding, it's polishing time.
Grab a rag and add your polish of choice, buff away, I tend to go with the 'grain' up and down the arm until it starts to look like a mirror
You may find a spot where the clearcoat hasn't been removed, repeat the 800/1200 sandpaper steps and re-polish.
It should end up like this.
As for weights:
133.2 for Drive Side:
172.6 for Non-Drive Side:
For a total of 305.8g - Sanding saves 3g, not the main reason for doing it, I just prefer no Sram Logo's on my Shimano equipped bike. Obviously, this voids your warranty also!
Just waiting on the Black Ti Bolts for the Powermeter to attach to the arms + the Cybrei Carbon rings (which I will remove the logo's from also)
lock40Nm
by lock40Nm
2K lacquer protects against scratches and sun, pure carbon is very soft.
Viner Maxima 5500 grams
Giant TCR SL 6500 grams
stevec1975
by stevec1975
Not worried about scratches, I have done this on multiple cranks over the years and they stay mirror finish for years in my experience, carbon is fine and most modern resins I understand to be UV stable these days, certainly will be fine for the expected lifetime of this product for me, otherwise Darimo et al, who leave their products in an 'unfinished' state, would have a problem. I do have 303 if needed.
stevec1975
by stevec1975
More bike bling of dubious value!
AbsoluteBlack 'Ultimate' Center Lock Ring, beautifully machined.
5.2g
10.5g the pair
Saves a massive?! 5.4g over standard Shimano ones.
Aryeh
by Aryeh
stevec1975 wrote:More bike bling of dubious value!
5.2g
10.5g the pair
I'm using Ashima ones that came with a centerlock adapter. They are 5.8g
Sent from my Pixel 9 Pro XL using Tapatalk
stevec1975
by stevec1975
The upgrades continue..
Changed out the Bolt for the EXS Stem Cap to an Extralite Hyperbolt, 1 for looks, 2 for weight saving
Saved a massive! 0.8g
I bagged some bargain Cybrei Carbon Chainrings in the BF sale, absolutely love the look of these and they should tie in nicely with the Alptitude Saddle
50 Tooth - 106.6g
34 Tooth - 27.5g
Cybrei Bolts - 7.4g
Very small weight penalty over DA Rings of 5.5g (50t) and 1.3g (34t), + the required bolts 2.3g (7.5g vs 5.2g for DA)
553.2g for everything except the 8 x Ti Sram Interface Bolts, when they turn up from Ti-Parts, should be approx 4g
Overall the change to E1 Arms, Xcadey PM and Cybrei Rings has saved 76.4g over D1 Arms, Quarq PM and DA rings.
I still need to remove the Logo's from the Outer ring, tried the usual suspects (Nail Polish with and without Acetone, White Spirit, Meths) with no luck, any suggestions?
justinfoxphotos
by justinfoxphotos
Really nice updates.
Awesome job on sanding off the logos on the crankset. Big balls! Looks awesome (100% less is more).
I got the AB lockrings too. Love the packaging, and finish on them is amazing (great weight savings too). I did notice they suggested to use loctite on their web site, but don't have any handy so have installed them without until I get some.
Saddle looks awesome, is it comfortable enough? I've been considering a full carbon saddle for the SL6 build (since that's my only real weenie build).
Love the Extralite stuff, and the temptation (in general) to move some of that stuff over to my new SL8 is strong, but I must not (lol!).
When the Cybrei crank set first appeared on the scene I loved everything about them except the name and logo (which have grown on me since), but removing that logo from the rings would (IMHO) really make the carbon be the true hero. SRAM Red is light enough, but I'd be lying if I say that I'm not at all considering a Cybrei crankset and chainrings!
stevec1975
by stevec1975
And they were gone:
All it took was some elbow polish!
