S-Works SL8 - Build (Never!) Finished - 5.94Kg
Introduce your new bike! Introduce yourself! Use metric.
stevec1975
by stevec1975
Changed to Galfer Wave CL, as my old discs are on the way out / in prep for going to the Alps in 3 weeks.
a 22g saving
S-Works SL8 - 6.19Kg/13.71Ib
Cervelo S3 Disc - 6.78Kg/14.94Ib
Scott Addict RC - 6.92Kg/15.25Ib
OnOne - Free Ranger - 8.68Kg/19.1Ib
Scott CR1 - 5.69Kg/12.54Ib
Aryeh
by Aryeh
tyro13 wrote:
Aryeh wrote:
Wed May 15, 2024 12:09 am
You can save more grams by swapping the barrel nut too but it requires some Dremel work because the readily available titanium barrel nut is 1mm too wide.ImageImageImage
Where can you buy that Ti nut?
I bought it here: https://a.aliexpress.com/_mNU7fMi
I bought the M6-10X14MM one and then had to Dremel it down to 13mm width to make it fit.
Sent from my CPH2583 using Tapatalk
stevec1975
by stevec1975
Thanks Aryeh
Used the one from Ti-Parts that comes with the SL8 Seatpost kit, and some filing down, to make an another massive 1.9g saving!
Up for any tips or tricks or recommendations to change to get this into the 6.2Kg territory
Aryeh
by Aryeh
stevec1975 wrote:Thanks Aryeh
I'm running a BB Infinite BB, it's 70g if I remember correctly. That'll save you around 20g.
You can also go with the new Red E1 crankarms, they are 30g lighter than D1.
You can change the Front Derailleur and Rear Derailleur bolts to alloy to save a bunch of grams. (Front Derailleur is M4x10 Flathead, and RD is M5x10)
You could probably also save 100g on the handlebars with the Avian Canary or Darimo Nexum Drag.
ryanw
by ryanw
BBInfinite BSA:
69g - 30mm
76g - DUB
88g - 24mm
SL8 R-Works - 6.19kg
IG: RhinosWorkshop
stevec1975
by stevec1975
Cheers, if the C-Bear BB ever goes awry then will go for BBinfinite.
• Sprayed the 3D Printed TI Computer Mount in Matt Black, to match the bars
• Moved back from a CS OSPW to the Standard DA cage, the main thing I noticed is that shifting is 'crisper' now. Also saved 26.9G - Bike weight is now 6.34Kg
In other news, also got some new decals to make the frame 'pop' a bit more - Satin Chrome decals (I get that Satin Chrome is an oxymoron) - Love them, really suit the frame well in my view.
Alex222
by Alex222
Looks great. How did you find applying the new decals? Keen to change mine on my RTP, but worried about messing it up.
stevec1975
by stevec1975
Cheers, Decals are from speedydecal.com, as long as you take your time, they are easy to install. They only overlap the original decals by 1mm or so, so just mark out the extremes of the original, and use that as the start point.
V35
by V35
Awesome build
stevec1975
by stevec1975
Few pics from recent trip to the Alps.
Also, build now down to 6.29Kg, after swapping the cassete back, post alps, to an 11-30 DA one.
squid046
by squid046
stevec1975 wrote:
Thu Jun 20, 2024 6:03 pm
Could you take a closer shot of the decals?
stevec1975
by stevec1975
squid046 wrote:
Mon Jul 08, 2024 12:57 pm
Not sure what you are looking for, but here are a few close-ups.
V35
by V35
If you aren't already- Use shimano lockrings on the galfer rotors instead of the Galfer lockrings that come with the rotors to save more weight.
squid046
by squid046
stevec1975 wrote:
Tue Jul 09, 2024 5:52 pm
I appreciate the pics. I believe you said you overlayed the decals on top of the originals? If so, I wanted to see how close the edges were.
stevec1975
by stevec1975
Ahh, I see, you can kind of see it on the R letter on the first pic, a small indent where the original letter is, either way, it comes out about 1mm bigger allround, over the original.
