S-Works SL8 - Build (Never!) Finished - 5.94Kg
Introduce your new bike! Introduce yourself! Use metric.
stevec1975
by stevec1975
and so it begins..
Will document my build, including weighing anything and everything, in short order.
Just waiting on delivery of the final pieces of the puzzle.
Frame Weight 682.5g (Below weight includes Front Mech Hangar (12g))
Fork 344.6g (uncut)
S-Works SL8 - 6.19Kg/13.71Ib
Cervelo S3 Disc - 6.78Kg/14.94Ib
Scott Addict RC - 6.92Kg/15.25Ib
OnOne - Free Ranger - 8.68Kg/19.1Ib
Scott CR1 - 5.69Kg/12.54Ib
mike
Resident Pro
by mike
wow gorgeous!
bmrk
by bmrk
Looks good
Which color and frame size?
da123
by da123
stevec1975 wrote:
Sun Apr 28, 2024 12:13 pm
and so it begins..
Fork 344.6g (uncut)
Lovely 🥰. What size frame is that? Great weight for a non RTP 👍
stevec1975
by stevec1975
It’s a 54cm 'Supernova' colourway, it’s certainly lighter than I was expecting!
stevec1975
by stevec1975
Some parts have begun to arrive..
Still waiting on the 380x110 EXS Aerover Bars (Stuck in Customs for 10+ days)
EXS Aerover - 3d Printed TI mount
14.8g
EXS Aerover - SL8 Transition + 10mm Spacer
20.5g
DA 11-34 Cassette
256.2g
Rhinoworks DM Hangar:
11.7g
C-Bear Ceramic BSA BB
95.5g
stevec1975
by stevec1975
More goodies have arrived:
The rarer than rocking horse shit EXS Aerover in 380x110
318g with spacer and head cap/bolt.
Swapped out the bolt in the Seat Wedge to the specific one from Ti Parts
A whopping 3.8g saving!
Before:
After:
stevec1975
by stevec1975
Chopped some 60mm off the seatpost, and changed out the bolts to Black TI
A 14.6g saving!
Anyone know of a source for a carbon cradle that fits (the current one is 17.1g and the ones I have are about 12g, but too shallow to fit)
Aryeh
by Aryeh
You can save more grams by swapping the barrel nut too but it requires some Dremel work because the readily available titanium barrel nut is 1mm too wide.ImageImageImage
stevec1975
by stevec1975
Thanks Aryeh, when you say readily available barrel nut, where did you buy it?
Also, cut down the fork (as will only need a 10mm spacer)
344.6g > 333g - a 11.6g saving
Incidentally, the frame and fork combo comes in at 1015.5g, pretty light!
And had to cut down the Spec expander (the fork was finished quite badly inside, which stopped the plug going in all the way at full length)
A 9.3g saving (Still toying with getting the Aethos or Carbon-Ti Expander to save another 20g's)
stevec1975
by stevec1975
So, finally got round to finishing the build:
6.37Kg all in. Powermeter, 50mm Wheels, DI2, Garmin Mount.
First Ride was yesterday on a Sportive, the bike felt amazing, so responsive accelerating up climbs, corners like on rails, would go as far to say it's the best bike I have ridden...
K4m1k4z3
by K4m1k4z3
stevec1975 wrote:
Wed May 15, 2024 12:27 pm
It's supposed to be like that. There's a ridge and reinforcement down in the fork steerer.
'24 S-Works Tarmac SL8 RTP|Ultegra R8100|Alpinist CL / Custom Rapide CLX 2x60
'19 Diverge E5 Comp
'23 Epic Pro LTD
'22 Status 160
bmrk
by bmrk
Amazing build, thanks for the write up!
stevec1975
by stevec1975
K4m1k4z3 wrote:
Mon May 20, 2024 9:14 pm
I get the need for the ridge and the reinforcement around the hose exit hole, but this was a mess inside. I ended up using a Carbon-Ti X Bung thing anyway..
tyro13
by tyro13
Aryeh wrote:
Wed May 15, 2024 12:09 am
Where can you buy that Ti nut?
