52cm Specialized Tarmac SL8 Pro Blue Onyx - 5.87kg
SRAM Red E1 is now installed.
I switched from 48/35T 170mm to 50/37T 165mm. (New Red was 5g lighter despite the bigger chainrings because of the lighter crankarms).
I switched to the 10-36T Cassette from 10-33T. The weight penalty is 25g.
The bike now weighs 6.015kg with pedals, computer mount, radar mount and bottle cages.
The bike would be sub 6kg with the 10-33T cassette.
It'll be sub 6kg with the Darimo Nexum Drag that I ordered today and will probably arrive in November.
My first ride will be tomorrow morning and then I'm doing an imperial century on Sunday so we'll see how it rides.
I basically never ride in the drops. On descents I ride in the aero hoods position which is faster than the drops and with these new levers I can actually brake in that position because the force required to brake is so low with the new levers I can brake with my fingers at the top of the lever near the pivot point.Nixster wrote:This is such a great build for a non S-works frame, great colour too.
The reach to the brakes from the drops looks pretty big though, how is it in practice?
Sent from my CPH2583 using Tapatalk
It seems like I don't really need the 10-36T Cassette on most rides and the 10-33T should suffice. So I'll keep the 10-36T for very hilly days and have the 10-33T as my daily driver.
The attached screenshot is from a ride I did on Sunday, 103mi with 7000ft elevation.
Might have missed this but was the darimo offset post not in stock? Seeing how you're setup it seems that one would've been a better fit?
Current bikes: '24 S-Works Tarmac SL8, '24 Specialized Allez Sprint
Disgusting list of bikes owned
A setback seatpost probably would've been a better choice. I got this saddle after I got the seatpost and my last saddle had longer rails, so the inline post wasn't an issue.gurk700 wrote:Might have missed this but was the darimo offset post not in stock? Seeing how you're setup it seems that one would've been a better fit?
did they size up to what ENVE states or come in a little oversized like the 29's? i have been thinking about some 27's - my rims are a tad under 29 external and 21mm internal.
On my 25mm int rims they measure 29mm at 70psigbrnole wrote:did they size up to what ENVE states or come in a little oversized like the 29's? i have been thinking about some 27's - my rims are a tad under 29 external and 21mm internal.
Enjoy reading your build process. Impressive sub 6kg for a non s-works frame!
Going from the older AXS shifters to newer, is the reach that much longer? Is it a big difference on body when riding longer distance ( Specifically wrist, neck and shoulders).
I can't tell the difference and I did 120 miles on Sundaycorkycalvin wrote:Enjoy reading your build process. Impressive sub 6kg for a non s-works frame!
