My custom painted Cervelo Caledonia (7,65kg)
So, I got my Cervelo Caledonia repainted and now it will be build up with basically all new parts.
(I will keep the headset and seatpost clamp )
It was regular 105 build and the weight out of the box was 9,25kg! I will be happy if I get it under 8kg.
Size 56 frame weight: 1131g (no hardware)
Cut fork weight: 411g
I saw this on the Unlimited Colors instagram profile, do you mind sharing the cost for it? Looks good!
It was 1050€ for the paint + another 100€ for removing this ugly toptube mount crater.dudemanppl wrote: ↑Mon Apr 24, 2023 5:13 pmI saw this on the Unlimited Colors instagram profile, do you mind sharing the cost for it? Looks good!
It's all smooth now, will share a picture when the bike is built up.
It's intended to be used for a bolt on toptube bag but you could as well mount a water bottle cage.
Anyway, that possibility is gone
Very nice paint job!jayjay wrote:So, I got my Cervelo Caledonia repainted and now it will be build up with basically all new parts.
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
- Factor LS Disc
Finished!
7.65kg with Garmin Rally pedals
No more top tube mounts
Most of the parts I used:
