Basso Diamante 2023 build
storcky
by storcky
Frame size 56 incl. clamp & der.mounts - 830g
Battery holder & plugs - 8g
Basso thru axles - 73g
Fork cut - 319g (348g uncut)
Expander Basso - 53g
Seatpost Basso 15mm - 193g
Bar Stem Basso 400x110 - 335g
Garmin mount Basso - 26g
Aiming for a sub 6.6kg build. 12s Ultegra/DA mix. Campagnolo pre 2015 SR crankset. Berk saddle. Wheels - Duke Bacarra Ultra 42s, CarbonTi Hubs, CX-Ray, Galfer rotors, Veloflex tires. Should get a durable everyday use build...
nismosr
by nismosr
wow .. 830g for a size large .. this is going to be awesome.
2020 Colnago C64 Mapei-SR12 EPS-WTO 60
2021 Basso Diamante SV-SR12 Disc EPS-WTO 60
2023 Colnago G3X-SRAM AXS Force-Levante
dalord774
by dalord774
Is that white or silver? The description always talks about white, in the pictures you can see it badly ...
Look 695 / 6,5 Kg
Colnago Master / 8,7 kg
Baum Ristretto / 7,6 Kg
MrCurrieinahurry
by MrCurrieinahurry
Looks awsome cant wait to see how this turns out
Basso Diamante eps 12
storcky
by storcky
dalord774 wrote:
Thu Dec 29, 2022 1:48 pm
The color is called "opal white". Same color as on the last Diamante model or Diamante SV. It´s a cold, blue greyish off white with perlmutt effect that turns out especially in sun light.
mike
Resident Pro
by mike
Saw a Diamante in the shop today in white and blue. Such a fabulous bike
r1der
by r1der
An aesthetical return to form for Basso. After the 2019 Diamante with the sunken stem. The old one rides better than it looks.
I would have loved the rim brakes on the new models, which could have accentuated the slender fork.
itsacarr
by itsacarr
Great to see another Basso on the forum. Look forward to ride reports.
Just ride ..
storcky
by storcky
Got the wheels today :D
Duke Baccara Ultra 42 - Carbon Ti X-Hub SP Disc Hubs - 24/24 Sapim CX-Ray & Sprint Spokes - TL Rimtape - 1291g
Galfer Discs - 160mm & 140mm with Screews - 178g
Veloflex Corsa Evo 25mm Tires - 214g + 212g
Revo.Race Tubes - 40g + 40g
Beancouter
by Beancouter
Hi Storky, out of interest did you do any research on the frame weights in the 3 colours? I had assumed the gloss would be heavier altho your white one is Rear carbon at the rear which might bring the weight down.
I have emailed b Basso but not optimistic I will get a response!
storcky
by storcky
I have not details to this but assume that the black matt color scheme is the lightest one. red maybe is heavier than opal white because the red is painted at the rear end as well - not only clearcoat as the opal one.
Beancouter
by Beancouter
storcky wrote:I have not details to this but assume that the black matt color scheme is the lightest one. red maybe is heavier than opal white because the red is painted at the rear end as well - not only clearcoat as the opal one.
Thank you - they were my thoughts but would be really surprised if the black came in lighter than your opal white one…
storcky
by storcky
The black is just matt clearcoat...i would name it "matt carbon"...only one thin layer of paint.
Beancouter
by Beancouter
storcky wrote:The black is just matt clearcoat...i would name it "matt carbon"...only one thin layer of paint.
Ooooooh ! Black it is Image
Beancouter
by Beancouter
Ordered! Thanks for giving me the nudge - was a bit worried the frame would be well over published weight.
