Extralite Scr-580 Build - sub5 - 4,61 kg
xsnailx
by xsnailx
I am still waiting for darimo seatpost and stem from r2-bike, they shall arrive end of this month hopefully.
i decided not to use the extralite upper headset part that comes with the frame and opted for normal one with slam that stem ultralight cover - it is only ~10g more but easier servicable than extralite micro bearings.
I will use rear xx long cage derralieur tuned with kcnc ceramic wheels and red front derralieur + xx 11-36 casette. it takes another 20 g of penalty but offers me a 34/36 gear that i can use to climb 29% hill with high cadence
will post build photos as soon as the darimo parts arrive
poulhansen
by poulhansen
xsnailx wrote:
Wed Oct 26, 2022 7:05 pm
Morkai wrote:
Wed Oct 26, 2022 1:47 pm
xsnailx wrote:
Tue Oct 25, 2022 12:00 pm
frame has 975 gram with - deralieur hanger, seatpost clamp (darimo), extralite headset, and token(BB30-TBT) support bearings
You mean frame+fork, right?
Yes, frame + fork+ bottom bracket bearings+ front derralieur Clamp + seatpost Clamp (darimo) + headset , size m
Aha, I almost skipped the thread when I saw frame = 975 g ;-)
Cannondale Super Six HiMod 2017 6.7 kg
Cannondale six13, 2004, 5.50kg
Focus Izalco Max, 2023 4.418 kg
xsnailx
by xsnailx
poulhansen wrote:
Tue Jan 10, 2023 12:42 am
frame is 589g only :)
i really hope to reach around 4,6 kg on tubular wheels without compromising durability - so no fancy brake cables / liners (i plan to use jagwire polished cables and nokon) and driveabilty (eebrakes wich really works vs fibula wich works altough alternate way ;-) )
xsnailx
by xsnailx
Finally the darimo parts arrived - so i can move forward with the build
- unfortunately kcnc ti casette 11-36 10 speed is unobtanium :( so i have to settle on sram
- i am still thinking wether to use classic red + carbon chain cathcher on ti bolt or yaw one FD
if time permits (and kmc sl chain arrives) i shall have it ready by the end of the weekend
here is how it looks now:
nickf
by nickf
Love the build. Haven't seen one of those ti red fd's in a long time. My last two cracked unfortunately.
poulhansen
by poulhansen
Hello, did you make that repair stand adapter yourself?
xsnailx
by xsnailx
I have two workstands and none of them is able to hold bike dropout-style and i am afraid of cracking the frame if i mount it via seat tube or top tube, and darimo does not permit to use seatpost to hang a bike)- this one is quite old and not used now - i so i decided to make an adapter to be able to hold the bike via fork and under the support, i have used an old pad from tt handlebar under the support and car fork dropout holder from local auction that i got for 1$ ;-) and a L shaped aluminium bar.
i am thinking of getting feedback spotrts sprint repair stand to match my omnium overdrive trainer that i use on the races
poulhansen wrote:
Thu Jan 26, 2023 2:11 pm
xsnailx
by xsnailx
Here she is - Fork will be cut after bikefit session and bartape will be installed then. i will make a better photos after fitting.
At the moment it is 4.700g but there is a few things that i would like to replace :
-> Casette into KCNC ti mtb 10 speed 11-36. (unobtanium atm :()
-> Lighter Qr's
-> HOPP tuned parts for rear derralieur
Since i would like it to withstand races using extreme parts like aluminium casette or track tubulars is not an option :)
SPECIFICATION:
Frame: Extralite SCR-058
Frame size: 54
Hubs: BITEX RAR9 + Novatec A291SB Superlight
Rims: Farsports FSD25t-23UL
Spokes + Nipples: dt aerolite + Alu Nipples
Headset: Ritchey Ti / enduro
Spacers: scott carbon
Brakes: EE
Shift + Brake liners: Jagwire link
Support: Token ceramic TBT for 30mm axle
Crank: THM Clavicula SE
Chainrings: Extralite 50/34
Powermeter: THM Clavicula built-in
Pedals: Xpeedo THURST Sl - Titanium axle
Chain: KMC X10 Sl
Seatpost: Darimo t1
Stem: Darimo IX2
Handlebar: Darimo Ellipse road
Seat Clamp: Darimo sub4 + risk hollow ti bolt
Tubulars: Vittoria Corsa Speed 23 mm
Waterbottle cages: chineese 3k @8g + aluminum screws
Topcap: Extralite
Derailleurs: Sram Red 10s yaw front + Sram XX long cage rear + Kcnc jockey wheels
Shifters: Sram Red 10s
Cables: Shimano Dura-Ace
Qr: Token, bolt-on with titanium axle
Cassette: 11-36 sram XG-1099, 10 Speed
Seat: Selle italia c59
AM7Jeremy
by AM7Jeremy
Curious how it rides?
xsnailx
by xsnailx
Didnt try yet :( too much snow here in Poland. Moreover it is awaiting a bikefit session
AM7Jeremy wrote:
Wed Feb 01, 2023 6:06 pm
shotgun1
by shotgun1
Awesome build! How do the rims perform? I've got the non-UL version, and debating of upgrading. Thanks!
2021 Giant TCR Advanced SL0 Disc 6.8kg
2019 Specialized Allez Sprint Disc 7.9kg
2017 Festka Scalatore 5.375kg
Original account [shotgun]: memberlist.php?mode=viewprofile&u=10594
xsnailx
by xsnailx
Hello!
I have ridden around 10 competitions on them last year - two of them included some cobbles. I have 70kg and ~300 FTP, though i am not a sprinter type and more of a cadence based rider. They performed flawlessly and the braking performance is good even in wet. Altouh i dont see much sense in upgrading non-UL into UL ones. I if only I didnt need a 11-36 casette for some 25-30% hills i would go for this ones in no time -> viewtopic.php?f=5&t=171564&p=1780655#p1780655
shotgun1 wrote:
Thu Feb 02, 2023 9:39 am
xsnailx
by xsnailx
This is how i squeezed jagwire barrel adjuster under the stays - i use xx derralieur wich beeing mtb one does not have any
xsnailx
by xsnailx
Finally i have installed extralite ultratop / ordered cane creek aer bottom bearing and schmolke clamps for shifters. What is funny that the extralite provided me the wrong enduro bottom bearing (triple checked with token headset measurment jig and frame / fork docs ;)). it was 36*45 instead of 45*45, thats why i have decided to get the cane creek one
tarmackev
by tarmackev
Wow!
I love this, classic weightweenies. Well done Xsnalx for keeping the spirit alive. Amazing build.
