Stillside's 3950g generic road build
Stillside
by Stillside
Annnnd ...
A custom cockpit solution I'm working on. Same concept as on current bike - use pursuit position, high-strength levers and mechanical formula, and friction shifting. In this mockup, everything is fully custom and scratch-built. There are a couple parts machined from 6061, a delrin shift lever, carbon levers, and a carbon bar/stem combo with nice thick 2.0mm walls on the stem area, going down to 1.5mm walls out on the handholds.
Total weight for entire cockpit and all hardware ... 262g. An additional shifter could be added to the NDS lever at any time, for a total cost of about 6-7g.
prebsy
by prebsy
this is pretty sweet. did you consider putting indexed shifting on it?
Stillside
by Stillside
No. Don't want to add the grams, and I've come to love the friction shifting.
Stillside
by Stillside
So I'm going back to the drawing board on this build. Got a brand new SuperSix (yes, different from the other SuperSix I posted earlier). This was a Black Inc version, managed to tune it down to 629.5g frame, 269.1g fork. Under 900g for the combo! Sanded the Dash seatpost to reveal the absolutely gorgeous weave beneath. Acquired an AX-Lightness Rigid 120mm stem at 78g. I have a bunch more custom parts in the works. This will be a special build.
CustomMetal
by CustomMetal
Just wow!
Allegra- Steel Lugs TBC
Aurelia- Stainless All Road 8.5kg
Bertha- TT 9.8kg
Perdita- Ti Turbo bike 8kg
Serenity- Ti Gravel 9.5kg/8.9kg
Verity- Ti Aero 8.2kg
Alya- Ti Climbing TBC
MrCurrieinahurry
by MrCurrieinahurry
Basso Diamante eps 12
ry5n
by ry5n
Wow, and no kidding. Just beautiful. Who is manufacturing the custom bar/stem, if you can talk about it?
mike
Resident Pro
by mike
Very nice!
poulhansen
by poulhansen
What model and year is the supersix?
Did you reach below 900g just by sanding the paint?
Cannondale Super Six HiMod 2017 6.7 kg
Cannondale six13, 2004, 5.50kg
Focus Izalco Max, 2023 4.418 kg
Fatbiker
by Fatbiker
What's your take on the saddle? I recently bought a beat up Dash Stage saddle and I am considering taking of the cover and padding.
