Airwolf YFM053
willrhyd
by willrhyd
I've been meaning to post a few pictures of a build from earlier in the year of an Airwolf YFM053. The total build cost was ~£2000 with forks off eBay and bars/seatpost also from Airwolf. The bike is a copy of a Specialized Epic HT in terms of geometry and has built up really nicely with some quite solid and reasonably priced components. There was one issue I had during the build in that the cable stop in the frame for the rear mech was too large-a-diameter and the cable ferrule pulled through. I had to buy one of these: https://www.ebay.co.uk/itm/403778549148 ... e4QAvD_BwE and grind it down slightly to fit snugly (not ideal I know). I'm not sure if it was the cables I was installing or what. The only other issue I've had is a creak from the bottom bracket, which might actually be the pedals but need to diagnose.
Frame: Airwolf YFM053 (large) - 1053g
Headset and bung - 133g
Fork: Rockshox Reba RL 100 - 1597g
Wheels: Hope Pro4 Fortus 23 - F897g/R1003g
Tyres: F Rocket Ron Addix Speedgrip 29x2.25 642g / R Racing Ralph Addix 29x2.25 745g
Brakes: Clarks M3 Rear 160mm rotor - 392g / Front 180mm rotor - 412g
Handlebars: Airwolf 680mm flat - 164g
Grips: Ritchey Foam - 42g
Stem: Hope 70mm
Seatpost: Airwolf 400mm - 218g
Cranks: XT 170mm 36T - Forgot to weigh
Bottom Bracket: XT Threaded
Shifter: SLX - 132g
Cassette: SLX 10-51T - 533g
Rear Derailleur: SLX - 311g
Chain: SLX - 280g
Total weight with pedals 10.21kg
mike
Resident Pro
by mike
What a great color!
