2022 Basso Palta 2
loup
by loup
I'm also considering building a gravel bike as training bike in addition to my road bike. I'm stuck betweent Diverge or the Palta2. Have you riden other gravel bikes? How does the Palta compare in riding & comfort.
nismosr
by nismosr
kode54 wrote:
Tue Jul 19, 2022 9:00 pm
nismosr wrote:
kode54 wrote:
Sat Jul 16, 2022 8:53 pm
Nice. How did you like the Schwalbe RS?
What gravel roads are these? Looks like some nice areas for NJ. I got a bit tired of the Colombia Trail.
oh its fast compare the cinturato H that I have or maybe because of the upgraded wheelset too 303s. cornering on lose gravel descent is pretty grippy too.
this is Bedminster .. the MEcca of gravel roads in northern NJ lol come by one of the Saturday we do a 33 mile that has about 18.6 miles of gravel.
Okay. LMK ahead of time location and time. I’ll join.
msg you my number .
2020 Colnago C64 Mapei-SR12 EPS-WTO 60
2021 Basso Diamante SV-SR12 Disc EPS-WTO 60
2023 Colnago G3X-SRAM AXS Force-Levante
nismosr
by nismosr
loup wrote:
Wed Jul 20, 2022 3:07 pm
Loup,
This was my only Gravel bike, my initial interest was on a 3t exploro and Cervelo Aspero when I was looking for a bike last year.
but I was looking fo something in expensive just incase if im not going to enjoy it, i didnt have to spend a lot. and when the new palta came out
and the price is with in my budget to build I jump on it and was very happy with the ride. also to let you know I used to have a Basso Diamante and currently have
the Basso Diamante SV.
loup
by loup
I'm currently really into it, buying a Palta2 too. The Basso steam is quite bulky and heavy ~260g acc. to the website. Also the minimum Basso stem lengh is 80mm...
With the internal cable routing, do you think its possible to make another stem soultion work. E.g. Extralite Stem with ~65g :P
nismosr
by nismosr
loup wrote:
Wed Aug 10, 2022 8:19 am
the problem is the HS cover and spacer which has the same shape as the basso stem. also the Palta HS spacers are made of Alloy not plastic or carbon.
sonic00
by sonic00
Can you please tell me what screw length you used for the Sram Flatmount Calipers?
Did you use 160mm rotors? If yes: are there adapters needed?
nismosr
by nismosr
sonic00 wrote:
Tue Aug 23, 2022 11:25 am
Hi yes 160mm and its the screw that came with front calipers .. and the caliper is mounted to an adapter already when i got the Rival AXS shifters.
req110
by req110
Can you please describe what happened with the fork? I see the carbon looks damaged. Is that from factory?
SW SL8 RTP 56cm @ 9270 / CLX II / CS OSPW / CEMA BB
S Epic 8 L @ XX T-Type / Berg Ratheberg 30 / Quarq / Fox Transfer SL 100mm / 3p
nismosr
by nismosr
req110 wrote:
Wed Aug 24, 2022 9:47 pm
which part of the fork did you see that look damaged ?
req110
by req110
nismosr wrote:
Mon Aug 29, 2022 3:32 pm
This part. Totally trashed. A life biohazard. If this comes from basso factory, I would be pissed off. I heard horrible stories from recent palta 2 owners.
nismosr
by nismosr
req110 wrote:
Mon Aug 29, 2022 4:26 pm
Thats a masking tape residue, fork is perfectly fine. Thank you
req110
by req110
Oof, glad to hear that. Now enjoy your bike. Sorry for panic.
RDY
by RDY
Could one of the owners say what the headset spec is? I'm guessing IS52 / IS52? If it's a standard bearing, third party stems and spacer stacks should be fine. Basso seem very unwilling for people to not ride their stem - which seems like a story repeated from the Diamante, which also turned off a lot of potential buyers.
nismosr
by nismosr
This weekend Gravel Ride with the Palta ..
kode54
by kode54
Nice! PA?
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
