not yet, sourlands only have a few that I know like montgomery road. you need to head north start from Bedminister where theres a lot of unpave roads, pass thru Trump Golf Course where both ends you either do the climb and nice descent. I did an 86 miles with mix pave and unpave with single track trail and a long stretch of Columbia Trail which started in Califon NJ.
2022 Basso Palta 2
2020 Colnago C64 Mapei-SR12 EPS-WTO 60
2021 Basso Diamante SV-SR12 Disc EPS-WTO 60
2023 Colnago G3X-SRAM AXS Force-Levante
when you say HS knocking .. when you turn side to side ? if so no.spokenwords wrote: ↑Sat Jun 18, 2022 3:01 pmNICE. Another great build and kick ass paint scheme. Do you get any headset knocking on any of your bikes?
- spokenwords
out of the saddle mainly. Im going to try another thin spacer above the stem to see if that helps. Maybe the headset adjuster is bottomed out on me.
"Notice how the door closes when the chimes of freedom ring." Joe Strummer
"this goes to 11" Nigel Tufnel
Dont move to Austin
Major Taylor rules.
Dont move to Austin
Major Taylor rules.
hmm so far not yet even with the SV ..spokenwords wrote: ↑Tue Jun 21, 2022 2:07 amout of the saddle mainly. Im going to try another thin spacer above the stem to see if that helps. Maybe the headset adjuster is bottomed out on me.
Nice. How did you like the Schwalbe RS?
What gravel roads are these? Looks like some nice areas for NJ. I got a bit tired of the Colombia Trail.
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
- Factor LS Disc
oh its fast compare the cinturato H that I have or maybe because of the upgraded wheelset too 303s. cornering on lose gravel descent is pretty grippy too.
this is Bedminster .. the MEcca of gravel roads in northern NJ lol come by one of the Saturday we do a 33 mile that has about 18.6 miles of gravel.
Okay. LMK ahead of time location and time. I’ll join.nismosr wrote:oh its fast compare the cinturato H that I have or maybe because of the upgraded wheelset too 303s. cornering on lose gravel descent is pretty grippy too.
- Factor LS Disc
- Factor LS Disc
