Klaster_1's Specialized Aethos S-Works (4.99kg)
Klaster_1
by Klaster_1
Build list:
Klaster_1's Specialized Aethos S-Works with light tires (4830g):
Klaster_1's Specialized Aethos S-Works, with light tires (4830g)
Klaster_1's Specialized Aethos S-Works, with heavy tires (5020g):
Klaster_1's Specialized Aethos S-Works, with heavy tires (5030g)
Original first post:
In this thread, I'll document my new build, an Aethos S-Works. The plan is to move the parts from the good old FM079. Unfortunately, you can't order weight weenie bike parts to Russia at the moment, so for the first iteration I'll have to get by with what I have. No detailed scale shots either until I settle down.
Maddie
by Maddie
Going to be very interesting!
mike
Resident Pro
by mike
Looking very nice!
Klaster_1
by Klaster_1
For BB cups, I'm going to reuse the BBInfinite BENG-PF-RD-BLK-ASMWS (62g). Unlike FM079 which uses a full-length Al insert for threads, the Aethos has individual threads on both shell sides (12mm long, btw). This means I can't run Di2 wiring as is without a spindle shield, which my cups didn't come with.
Aethos BB shell
Aethos BB shell
FM079 BB shell
FM079 BB shell
Just like @takolino, I plan to 3D-print my own shield. The cups don't have shelves on the inner surface, but there's 5 mm of thread dangling, so I'll put a sleeve over it. The shield outer diameter will be greater than the frame thread inner diameter, that's what the cut is for - so you could compress the sleeve during installation, reducing the diameter temporarily.
BENG-PF-RD-BLK-ASMWS spindle shield, version 1
The ABS shield should add ~5g. Wall thickness is 1 mm.
On a side note, the dangling cup thread serves no purpose, might as well cut it off.
Klaster_1
by Klaster_1
That's what looks like an EW-JC130 stuck in Enve handlebars. No idea how to remove it 🤦‍♂️
takolino
by takolino
I bet this will be good!
Good luck getting that out. If you can use the Di2 connecor puller, you may be able to pull it off the j-box. The risk is that junction might get stuck in the bar forever. I'd rather fish it out through the bar end.
Klaster_1
by Klaster_1
Another great job by the Birota (local bike shop), they managed to extract the wire. The other shop I asked for help gave up after looking at the mess for 10 seconds.
The spindle shield idea worked out well too.
Custom spindle shield
Custom spindle shield installed
Klaster_1
by Klaster_1
The Sigeyi direct mount hanger arrived today.
Sigeyi direct mount hanger weight
Aethos stock hanger weight
Aethos hanger bolt weight
Sigeyi direct mount hanger installed on Aethos
Aethos rear axle weight
kode54
by kode54
The Redshift direct mount hanger version has some reinforcement in the middle. I wonder if they did it because it bends?
I’ll take a pic and post later.
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
Klaster_1
by Klaster_1
kode54 wrote:
Fri Mar 18, 2022 1:40 pm
My custom FM079 hanger - which Sigeyi is similar to - worked flawlessly for three years, so I wouldn't worry about the hole.
FM079 DM hanger
FM079 DM hanger
Klaster_1
by Klaster_1
FD hanger removed.
Aethos front derailleur hanger weight
kode54
by kode54
Here’s the alternate version for the Aethos direct mount. Image
- Factor LS Disc
Klaster_1
by Klaster_1
Today I cut the fork to length, took me two walks to LBS because I was too lazy to take the frame with me the first time. Guys at LBS allowed me to use the tools for free (already sold most of mine), very generous of them. Overall, Aethos geometry is similar to FM079 sizing-wise, the head tube is lower, so put an extra 5 mm spacer on. Apparently, I don't have a 5 mm last-gen Extralite spacer, so the colors mismatch a bit. The heavy Alpinist seatpost on the photo will be replaced with 30 cm long Darimo T1 Loop when I'm able to purchase parts.
Aethos, work in progress
FM079 headset (55.35g):
Headset bearing upper: FSA MR042R (13,82g)
Headset bearing shims (upper): Noname (1,73g)
Headset bearing lower: FSA MR12RB (22,63g)
Headset dust cover: DIY 3D printed (1,66g)
Headset steerer wedge: Neco (1,93g)
Headset microshims: Noname (2,27g)
Lower bearing spacer: Custom (2,06g)
Steerer spacer: Extralite UltraSpacer CFRP 10mm (1,76g)
Top cap: Extralite Hypercap (2,84g)
Expander plug: Extralite Ultrastar 4 (4,65g)
Aethos headset (48.95g):
Headset bearing shims (upper): Specialized (0.59g)
Headset bearing lower: Specialized (21.54g)
Headset steerer wedge: Specialized (1.29g)
Steerer spacer 1: Extralite UltraSpacer CFRP 10mm (1,76g)
Steerer spacer 2: Extralite UltraSpacer gen-1 5mm (0.8g)
Specialized Aethos steerer spacer, 5mm
Specialized Aethos steerer wedge
Specialized Aethos steerer shim
Specialized Aethos lower headset bearing
Specialized Aethos upper headset bearing
Specialized Aethos steerer spacer, 10mm
Specialized Aethos dust cover
dudemanppl
by dudemanppl
If you set the shifters to use just the buttons on top to shift, you can remove the shifty bits in the right lever as well. ;)
Klaster_1
by Klaster_1
dudemanppl wrote:
Sun Mar 20, 2022 7:17 am
True, the levers have more capacity for tuning left, what you suggest would save ~12g. Drilling out lever mounting points can be done too. At this moment, that's not the line I am willing to cross, I'd like to keep the modifications reversible, and I also enjoy the ergonomics of lever-mounted buttons, especially given how much I use the drops. In general, I believe Di2 and AXS modifications have been underexplored, despite electrical systems being easier to modify than mechanical ones.
In the following days, I plan to re-do the wiring Aethos came with, eliminating the junction B by splicing the wires. Aethos also came with an EW-RS910, I plan to use it instead of the SM-EW90-A I had on FM079, connecting it by a single wire to the shifter, running a naked wire to the shifter outside the bar. A junction taped to the seat tube wouldn't look as good on Aethos.
Shimano EW-RS910 junction A weight
