Fara F/AR - Ltd Signature Edition paint
nequalsone
by nequalsone
The plan is to have a bike with larger tyres aimed at 99% tarmac / 1% gravel.
Frame was pre-ordered in March 2021 with expected delivery in August 2021, but it arrived 2 weeks ago to the Fara Experience Center in Oslo. It is yet to be collected as I am about to move. https://faracycling.com/models/F_AR
nequalsone
by nequalsone
Farsports Feder - FSD25CM-27T-SUD (Hookless) - CX-Super - RD230 hub (CeramicSpeed) with HG freewheel - 995g without rimtape.
Rear wheel - without rimtape
Front wheel - without rimtape
Stacked
nequalsone
by nequalsone
Seatpost - Elita One - 20mm setback - 350mm - 122g
Rear thru-axle - Tailfin - 62g
Crankset - Cane Creek with power meter - 170mm - 386g
Brakes - Trickstuff C21 for dot fluid
Handlebar - THM Frontale - 40cm/90mm - 217g
gravity
by gravity
nequalsone wrote:The plan is to have a bike with larger tyres aimed at 99% tarmac / 1% gravel.
Frame was ordered in July 2019 with expected delivery in May 2020, but it arrived 2 weeks ago to the Fara Experience Center in Oslo. It is yet to be collected as I am about to move. https://faracycling.com/models/F_AR
Did you get the year wrong? If not, more than 2years waiting period for a frame? Crazy stuff.
nequalsone
by nequalsone
gravity wrote:
Tue Jan 25, 2022 8:24 am
Haha, good spot, looked at the wrong e-mail. Amended the first post. Cheers!
nequalsone
by nequalsone
Pictures don't do it justice. It is a transparent black paint which shows the UD carbon weave.
bmCube
by bmCube
Interested in how these ride! Is the toptube underside storagebox included?
nequalsone
by nequalsone
bmCube wrote:
Mon Jan 31, 2022 4:20 pm
Bags (and fenders) were included if you preordered the first batch, but the bags (Roswheel) are a bit delayed. I was told that they expect the bags to be available in May when I picked up the frame today.
I forgot to ask, but I would be interested in the smaller bag which the F/RD has.
nequalsone
by nequalsone
Because it is a spider :)
nequalsone
by nequalsone
Broke the sleeve on the Kogel BB, the frame is currently at my LBS. Frameweight on a size 53cm is 1,015g including hanger, blanking plate for 1x and a gazillion bolts on the frame (small blanking ones for the Fidlock bag attachments and bolts for fenders).
In the meantime, some Token S-Box weights. The expander is proprietary and I can't use a standard top cap.
nequalsone
by nequalsone
I suck at mounting tyres. So I need to take a breather.
Weights excluding sealant. Tyres are Rene Heres Bon Jon Pass Extralight. I am envisioning 120g of sealant given how much sealant leak from the tyre walls.
Rear wheel - including 140mm XTR rotor (94g incl lockring), 11-46 Rotor 12x cassette (294g including lockring), Tubolight tubeless valve (6g) and Tubolight tyre insert 16g
Front wheel, including160mm XTR rotor (115g), Tubolight tubeless valve (6g) and Tubolight tyre insert 16g
Thru-axles (Tailfin did not fit the frame)
nequalsone
by nequalsone
An over-the-top pimped out rear derailleur - add 25g for the battery
Sprinter and climbing shifter - Ali
Force shifters coming from another bike. Red could be 6g lighter (CCache's groupset weight list)
Jonolsson
by Jonolsson
Looking for info about Fara, what about the bike?
Enviado desde mi 2201123G mediante Tapatalk
MiloAS
by MiloAS
Really impressed with the weight of the wheelset, once you've got it built up I'd be keen to know how you find them.
thirdsun
by thirdsun
Sorry to bring back this old thread but could you share some of your impressions with the Fara F/AR? I'm seriously considering this bike but can't find a lot of information about it.
  • Canyon Aeroad CF SLX 8 Di2
  • Cervelo Caledonia Rival eTap AXS
  • Vitus Venon Evo
  • Canyon Grail CF SL 8 Di2
