Bike #30: S-Works Aethos (not midget sized)
- MrCurrieinahurry
- Moderator
With the LB wheels it's gunna be sweeeet.. what depth did you go for?
Basso Diamante super record EPS 12
BMC slr01 ultegra Di2
Very nice build as usual, Ryan. Are you planning to do a full ride report, once the Farsports arrive? Here's hoping
Main ride Aethos Expert 2021 https://weightweenies.starbike.com/for ... 0&t=169445
First reserve Pegoretti steel 2012 Ciavete paint viewtopic.php?f=10&t=168091
Gotta wait for a DM hanger to really get an idea of how the bike rides.
6.175kg with the Farsports FSD30CM-28T-SUD and AXS Cassette:
Ride report once I hit 300ish miles
Ayy frame twinsies! I built my 61 up back in October and forgot this horror. This was the single longest step for me. I backed the screw out too far to feed the di2 wire and it took me ages (even with the park tool wiring kit) to get this thing back in place.
How's the shifting w/ the SRAM cassette? I did something similar but for 11 speed. I'm running Ultegra 8070 but threw a SRAM Red 11/30 11 speed on it to save some grams. Shifts OK (lags going down the cassette sometimes, I had to pick between clean up or clean down, couldn't get both), but it's much noisier than the Dura-Ace 11/28 I was using on a previous build.
I'd say that my experience with the XDR cassette matches yours. There are a couple cogs that are slow to shift down to and shifting as a whole isn't as crisp as the Edco cassette (I didn't use the 9200 so I don't know how it shifted). With that being said, it's not worse than eTap so at least there's that .
What center locks are you using on the rotors?
So, Farsports are probably going to be moved out of the rotation, you can read why here:
viewtopic.php?f=113&t=168025&start=15#p1729195
I ordered a pair of Mcfk 35 (21 internal) laced to DT 180 from Mcfk direct, so hopefully those will be here in a month.
Also, I was able to squeeze 35mm Panaracer into the frame but I got very slight rub on the NDS chainstay:
This is what it looked like with fatties on:
New kicks came in today from the motherland:
Purdy:
Purdy:
