5.790kg Tarmac SL7 With DA9200
It only took 6 months of waiting for stuff to arrive, but finally built. 5.920 kilos in this spec. Approx 270g more with my Roval Rapides.
Spec sheet:
Frame and Fork : SL7
BB : Wheels MFG
Wheelset : Extralite C338
Rotors : Hope
Groupset : Shimano DA 9200
Crankset : THM Clavicula Powermeter
Pedals : Shimano DA
Seatpost : Darimo
Saddle : Gelu E3
Bars : Roval Rapide
Tires : Maxxis High Road SL 25mm
Tubes : Revoloop
Cage : Tune
Garmin Mount : 3D Printed
Not ridden yet, other than round a car park.
Cheers, Dave
Spec sheet:
BB : Wheels MFG
Rotors : Hope
Pedals : Shimano DA
Seatpost : Darimo
Saddle : Gelu E3
Bars : Roval Rapide
Tubes : Revoloop
Cage : Tune
Cheers, Dave
You can also probably save a few more grams with one of these: http://www.sigeyi.cn/en/col.jsp?id=127
Would love to see full scale shot of this.
My math brings in out around 6,250g if a 52cm frame.
(Happy to eat my words!).
IG: RhinosWorkshop
IG: RhinosWorkshop
Yours 5910
Mine 6590
You save:
70 frame
290 wheels
70 seatpost
10 stem
50 bars
40 saddle
30 CS OSPW
120 PM
15 AirTag
50 tyres
20 rotors
765 total
I save (areas you can save):
100 pedals
10 cage
50 rings+ bolts
40 expander
10 hanger
210 total
555 less when corrected
6590 - 555 = 6,035
Missing 125g (hence my request for a full shot)
Mine 6590
You save:
70 frame
290 wheels
70 seatpost
10 stem
50 bars
40 saddle
30 CS OSPW
120 PM
15 AirTag
50 tyres
20 rotors
765 total
100 pedals
10 cage
50 rings+ bolts
40 expander
10 hanger
210 total
6590 - 555 = 6,035
IG: RhinosWorkshop
IG: RhinosWorkshop
Without seeing your build or weights its pretty much impossible to compare, and I don't understand some of your numbers. The relevant items from my build, as far as I can see from your list above are:ryanw wrote: ↑Sun Dec 19, 2021 8:48 amYours 5910
Mine 6590
You save:
70 frame
290 wheels
70 seatpost
10 stem
50 bars
40 saddle
30 CS OSPW
120 PM
15 AirTag
50 tyres
20 rotors
765 total
100 pedals
10 cage
50 rings+ bolts
40 expander
10 hanger
210 total
6590 - 555 = 6,035
Wheelset : 1080
Tires : 340 (are your tires 390g?)
Tubes : 48
Crankset with power meter : 325 (are your cranks and power meter 445g?)
Rings : 130 (are your rings 80g?)
Bolts : 8
Pedals : 236 (are your pedals 136g?)
Saddle : 55
Cage : 14 (is your cage 4g?)
Maybe my scales are off, but the bike shop put it on their scales and it matched, so I don't think so.
Having found a picture of your bike, I think you're underestimating / over-estimating a number of areas.ryanw wrote: ↑Sun Dec 19, 2021 8:48 amYours 5910
Mine 6590
You save:
70 frame
290 wheels
70 seatpost
10 stem
50 bars
40 saddle
30 CS OSPW
120 PM
15 AirTag
50 tyres
20 rotors
765 total
100 pedals
10 cage
50 rings+ bolts
40 expander
10 hanger
210 total
6590 - 555 = 6,035
Wheels : my Roval Rapides are 1420, so weight saving is 340, not 290
Tires : your turbo cottons are at least 240 a tire. The Maxxis are 170, so min 140, not 50
Crankset : your d-zero is circa 540 as far as I can tell from looking online, so 200, not 120
Rings : the carbon ti (I have a set) are around 107 in a 50/34, so your saving is 23, not 50
Tubes : unless you also have Revoloop, I suspect there's a further saving there
Frame and Fork : given the colour of your frame and the size, I suspect the saving is more than 70
Rotors : the hope rotors are 69 and 75, so I suspect more than 20 saving
I think that more than accounts for your 'missing' 125g
Not being funny, but I think you should try checking your facts before effectively accusing me of faking a photograph for the sake of gaining recognition from a cycling forum. A quick check of my previous posts and builds would have sufficed.
- Moderator
To be fair to Ryan he has probably built more top end SL7s and weighed them than anyone else so he is coming from a position of experience. I can understand why he would question things as a sub 6 SL7 is an amazing achievement so well doneda123 wrote: ↑Sun Dec 19, 2021 1:05 pmHaving found a picture of your bike, I think you're underestimating / over-estimating a number of areas.ryanw wrote: ↑Sun Dec 19, 2021 8:48 amYours 5910
Mine 6590
You save:
70 frame
290 wheels
70 seatpost
10 stem
50 bars
40 saddle
30 CS OSPW
120 PM
15 AirTag
50 tyres
20 rotors
765 total
100 pedals
10 cage
50 rings+ bolts
40 expander
10 hanger
210 total
6590 - 555 = 6,035
Allegra- Steel Lugs TBC
Aurelia- Stainless All Road 8.5kg
Bertha- TT 9.8kg
Perdita- Ti Turbo bike 8kg
Serenity- Ti Gravel 9.5kg/8.9kg
Verity- Ti Aero 8.2kg
Alya- Ti Climbing TBC
Bertha- TT 9.8kg
