5.790kg Tarmac SL7 With DA9200
Great bike and so many areas to drop weight still.
I'm waiting on Darimo to produce and in-line post before swapping over. I'm too fat for the saddle, unfortunately.
As much as I love the THM power cranks, the left only 4iii PM just doesn't have a good track record, so will stick with my Quarq / Carbon-Ti combo.
And can never own a bike without a CS OSPW, so always going to have an extra 30g there over the standard arm.
IG: RhinosWorkshop
IG: RhinosWorkshop
- Moderator
Why not the carbon Ti rings?
Allegra- Steel Lugs TBC
Aurelia- Stainless All Road 8.5kg
Bertha- TT 9.8kg
Perdita- Ti Turbo bike 8kg
Serenity- Ti Gravel 9.5kg/8.9kg
Verity- Ti Aero 8.2kg
Alya- Ti Climbing TBC
Bertha- TT 9.8kg
- Moderator
Have you tried the SLF system instead of CS?ryanw wrote: ↑Tue Dec 21, 2021 1:17 pmGreat bike and so many areas to drop weight still.
Bertha- TT 9.8kg
Bertha- TT 9.8kg
I used carbon ti rings with SRAM AXS and they were a total PITA. Constant chain drops in both directions unless it was set micro millimetre perfect. In the end, I only dared to change up or down in cogs 2-9. Any others and you risked a drop or a non-shift. Eventually wrecked my drive side chainstay due to jammed chain which smashed the carbon. I couldn't get it to work at all with a flattop chain. The KMC X12 was better but still a compromise. Eventually gave up, switched to SRAM crank and rings and it worked flawlessly straightaway.
They may work better with Shimano of course, given front shifting is better and more forgiving of setup with Di2 than AXS. However I've tried to get confirmation of compatibility of the rings with 12s DA from carbon ti, and they can't confirm this yet. I may consider it down the line as they do look fantastic, but the shifting woes when used with AXS have made me pretty wary tbh. The Praxis rings are only a 23g penalty too.
You would have been using the V1 rings on SRAM which were shit. I aided in the production of the V2 rings which now work perfectly (it was actually just the big ring that was problematic).
They work fantastic on R9200 also.
IG: RhinosWorkshop
IG: RhinosWorkshop
I was using the X-AXS rings. How do you determine if they're V1 or V2? I assume the X-AXS rings aren't for use with DA9200 though, given they're only available in the SRAM ratios (46/33 etc.)?
Nice color on the frame ..looks great.
Cheers. I did originally have a 'Speed of Light' colour scheme frame on order, but after enquiring, Specialized told me the paint job added 'between 200 and 300g' to the frame weight! I have always like the carbon / chameleon green colour, the only downside is that so does everyone else, so its not exactly exclusive...
- Moderator
Only way I know is confirm it with Carbon Ti when ordering... but your experience screams of V1
Bertha- TT 9.8kg
Bertha- TT 9.8kg
Okay, thanks. In which case I think I'll email Carbon-Ti and politely ask if they'll exchange my two expensive sets of paperweights for versions that actually work!CustomMetal wrote: ↑Tue Dec 21, 2021 6:45 pmOnly way I know is confirm it with Carbon Ti when ordering... but your experience screams of V1
They are indeed offering an exchange service for those with V1 AXS rings.
The serial numbers are tiny, but found on the inside of the rings.
They'll only exchange the big rings since small ones are fine.
IG: RhinosWorkshop
IG: RhinosWorkshop
Hey da123, have you ridden the bike yet/ride report, interested on feedback on the tyre's, I got a set a while ago (as they save 119g over Conti), but saving them for Spring/Summertime
Cervelo S3 Disc - 6.78Kg/14.94Ib
Scott CR1 - 5.69Kg/12.54Ib
Scott Addict RC - 6.92Kg/15.25Ib
OnOne - Free Ranger - 8.68Kg/19.1Ib
