Factor LS 2021 AXS
req110
by req110
Let me show you my secondary bike, a gravel bike.
Size 54cm, i am 181cm, inseam 86.5, saddle height around 755mm. Stem 10cm.
Frame: Factor LS
Groupset: Sram Force AXS, except few mods
Rotors: Galfer wave road centerlock 160/140
RD cage: Garbaruk RD cage to accept up to 52 cassette, but that does not work properly, so i use
Cassette: Sram Force XPLR 10-44 (or Eagle X01 10-50)
Crankset: Sram Red Dub 175mm + Sram Pressfit 79mm DUB
Chain: Sram X01
Wheelset: Zipp 303s CL XDR
Tires: Continental Terra Speed 700x40
Sealant: 2x 40ml Stans No Tubes
Cockpit: Farsports F1 400x100
Bartape: Acros Mellow + Ciclovation Suede Touch
Seatpost: MCFK 420mm, 0mm offset
Saddle: S-Works Power ARC 155mm (i would prefer 143mm)
Pedals: Bontrager Comp MTB
Cages: Bontrager XXX (using with Camelback Podium, haven't dropped it yet)
Weight is really variable, it's roughly around 7.9kg, but i need to do some further measurments.
robbosmans
by robbosmans
That derailleur doesn’t look right
CamW
by CamW
Agreed, it looks odd. Like maybe the B-Screw isn't properly sitting on the little nubbin on the derailleur hanger.
cerro
by cerro
Great bike, skip the extension part and it will look better and still work great with the XPLR cassette. Am using that myself :)
Why not a flattop chain as the cassette is made for?
req110
by req110
This Garbaruk RD cage is ok, it does not look odd, it's just crunched while resting on smallest cog.
Chain is X01 because i was using eagle 10-50 cassette before.
Let me elaborate about extension part.
req110
by req110
I have just removed the extender from garbaruk RD cage, good point, thank you. Not much difference in the look of the bike, but I like removing unnecessary parts :)
ryanw
by ryanw
Some people need to learn how to build a bike...
RD isn't mounted correctly.
Should look like the attached.
40c tyres also need at least 60ml of sealent in them.
SL7 S-Works - 6.59kg
OPEN U.P.P.E.R. - 6.76kg
www.rhinosworkshop.co.uk
IG: RhinosWorkshop
req110
by req110
The RD was mounted on extender (Garbaruk G-Link, part of the scope of "GARBARUK derailleur cage system SRAM eTap AXS 12-speed for cassettes up to 52 teeth" which i have) because I was using wheelset with 10-50 cassette alternatively, and it was even more necessary there.
Seems G-link part can be skipped when using 10-44 cassette, as cerro suggested, so i have done that yesterday.
Sealant is dependant on how often I am switching tires, and I do this often.
req110
by req110
Obsession with numbers made me purchase Quarq Dzero 5x110, with 40T Absolute Black oval chainring.
I was struggling to find a tutorial on which position should be the chainring, so i alligned it based on pictures on their site and instagram. Hope it's fine, i will have a ride maybe tommorow, since i need to tune my new MTB.
mcal8055
by mcal8055
I need an update on how the Eagle derailleur performs with an XPLR cassette. I've considered it with my Ratio kit, but highly doubt it actually works well.
req110
by req110
There is no eagle RD on this bike. I have Force AXS with Garbaruk cage + XPLR cassette.
I don't see why XX1 Eagle AXS shouldn't work on this bike.
mcal8055
by mcal8055
req110 wrote:
Thu Oct 07, 2021 8:10 am
Wow, my bad! The positioning of that Force derailleur threw me off. I have a Garbaruk cage on my Eagle RD and I guess I thought it was the same.
LegPower
by LegPower
Have you tried this setup with a 10-33 or 10-36 cassette? I just ordered my Garbaruk cage and want to have two sets of wheels. Trying to figure out my second cassette.
req110
by req110
I think i tried my other wheelset out of curiosity, that has 10-33 and it was working fine.
