Includnig this one for completeness.
I got into this bike completely by accident. I ordered Yoeleo C58 disc brake wheels by mistake thinking that I had ordered the rim brake version. Rookie mistake. So I salvaged it by buying a cross frame and have since done a few cross races (and can also ride gravel with it).
I'm not sure I'd buy a ICAN frame again. It's pretty heavy and rides pretty harsh (especially compared to my Fuji Transonic and Trek Emonda, which both have integrated handlebars).
I went with Spyre mechanical disc brakes because I didn't want to faff with all the hydraulic fluid and also order a bunch of new tools. After taking this picture I have since adjusted the position of the shifters on the handlebars. Initially they were way too low.
Shimano Dura Ace BB86, SM-BB92-41B, pressfit 54g
TRP Spyre SLC mechanical disc calipers 323g
TRP flat mount adapters 44g
Jagwire Road Pro (compressionless) 100g (uncut)
SRAM CenterLine Center-Lock Disc Brake Rotor 140mm 102g
SHIMANO SM-RT64 BRAKE ROTOR W/ LOCK RING 160mm 162g
Shimano Ultegra 11-28 cassette (didn't weigh) -- I run a 11-30 for cross races
Shimano Optislik shift cable set 198g (uncut)
SRAM PC-1051 Bike Chain 10-Speed 257g
Shimano 105 FC-R7000 Crankset 52x36, 170mm Crank, 24mm spindle 748g (I've been running a 50=34 crankset for races, but maybe a 48-30 is next)
Shimano Ultegra FD-R8000 Front Derailleur, braze on 88g
Shimano Ultegra RD-R8000 11SP Derailleur, long cage (didn't weigh)
ICAN AC388 cyclocross frame, BB86, flat mount, thru axle, Toray T700 carbon 1070g
ICAN fork: 1-1/2" to 1-1/8" 468g (uncut)
Handlebar Tape 48g
EC90 Full Carbon (Chinese copy) handlebars, reach: 130mm, drop: 80mm, width: 400mm 267g
EC90 Carbon (Chinese copy) seatpost 27.2mm / 350mm 176g
FSA, 1 1/8" upper - 1 1/2" lower, integrated (included) 133g
Og-Evkin carbon spacers 11g
Promend PD-R87 flat pedals 241g (haven't mastered unclipping and reclipping on the run yet)
Oval Concepts saddle 238g, steel rail - I run a lighter saddle during races
Shimano 105 ST-5800 shifters 488g
UNO 80mm, alloy, 31.8mm +/- 7 deg, 97g
Schwalbe G-One Speed Tire - Tubeless, 32mm 635g
12x100/124mmL/16mmTL/M12x1.5mm thread, 12x142/168mmL/16mmTL/M12x1.5mm 145g
Yoeleo SAT DB C58 carbon rims 700c x 27c 1623g
while there's a bottle cage in the picture, I take it off for cross races.
Total weight: 8.41kg
ChooChoo bike 2 of 4: ICAN AC-388 cross bike / 8.41kg
2018 Fuji Transonic 2.5 rim (6.90kg)
2020 ICAN AC-388 cyclocross bike (8.41kg)
2021 Trek Emonda SLR RSL H1 rim (5.65kg)
1980s vintage ALAN Super Record (haven't weighed it)
