Canyon Ultimate SLX (was "8.0") (6.8ish kg // Crashed // Retired )
kroem
by kroem
Thought I'd do a gallery now that I've swapped (imho) up the groupset.
Bought as a SLX 8.0 SL (some limited release?) with Force AXS. Swapped group this year to a GRX/Ultegra mix. I prefer to deal with Di2 and I have two other bikes on the same system. Soldered my own blip buttons, and stuffed it into the bar. Since the cable holes are too small on the CP10 I had to solder the buttons when cables were in place. Weight is about 6.8kg
Build:
Part Name Weight Note
Total (gram) 6709
Total (lbs) 14,79
Frame Canyon Ultimate CF SLX Disc 890 * estimate
Fork Canyon One One Four SLX Fork 370 * estimate
Seatpost Hylix 27.2 165
Seat collar Canyon internal
Saddle Alptitude Gardena 70
Handlebars Canyon CP10 380x90 320 * estimate
Tape + plugs Cinelli Cork 45
Stem Canyon CP10
Headset Acros
Top Cap Acros
Spacers Acros
Levers/Shifters
Front Brifter Lever Shimano ST-RX815 250 * estimate
Rear Brifter Lever Shimano ST-RX815 260 * estimate
Brakes
- Front Caliper Hope RX4+ 99
- Front Pads Hope pads
- Front Rotor Galfer Wave 160mm 98 * estimate
- Rear Caliper Hope RX4+ 108
- Rear Pads Hope pads
- Rear Rotor Galfer Wave 160mm 98 * estimate
Front Derailleur Shimano Ultegra R8050 129 * estimate
Rear Derailleur Shimano Ultegra R8050 278 * estimate
Cables/Housing
Crankset SRAM Red AXS D1 337
- Chainring 1 Gearoop Kom Challenger 48/30 149
- Chainring 2 -
Bottom Bracket SRAM BB86 100 * estimate
Cassette/Freewheel SRAM Red XG-1190 11-26 155 * estimate
Chain Guide/Catcher
Chain SRAM Red22 240 * estimate
Front Wheel Light Bicycle AR45 1419
- Front Rim Light Bicycle AR45 Disc Flyweight hook
- Front Hub Novatec D411SB
- Front Spokes Sapim CX Rax Straight Pull
- Front Nipples Sapim Polyax Secure Lock
- Front Tape/Plugs No hole rim
- Front Tire Specialized S-Works Turbo RapidAir 270
- Front Tube Tubeless + Orange Seal valve 5,5
- Front Sealant/Glue Orange Seal 20
- Front Skewer/Bolt J&L Thru axle 19
Rear Wheel Light Bicycle AR45
- Rear Rim Light Bicycle AR45 Disc Standard hook
- Rear Hub Novatec D412SB Sram XDR
- Rear Spokes Sapim CX Rax Straight Pull
- Rear Nipples Sapim Polyax Secure Lock
- Rear Tape/Plugs No hole rim
- Rear Tire Specialized S-Works Turbo RapidAir 270
- Rear Tube Tubeless + Orange Seal valve 5,5
- Rear Sealant/Glue Orange Seal 20
- Rear Skewer/Bolt J&L Thru axle 26
Pedals Assioma Favero 300
Bottle Cage 1 Tune Wasserträger 14
Bottle Cage 2 Tune Wasserträger 14
Miscellaneous 1 HideMyBell raceday fi 37 26g + 11g
Miscellaneous 2 Shimano Di2 BT-DN110 Batteri 55 * estimate
Miscellaneous 3 Shimano Di2 bar-end junction 20 * estimate
Miscellaneous 4 Shimano Di2 SM-EWWU111 Wireless Unit 3
Miscellaneous 5 Shimano Di2 cables + 4-port + y-cable 50 * estimate = 20g + 5g + 25g
Miscellaneous 6 Capgo Noise Protect 5
Current
Waltly Gravel (stolen... and found!)
P-X Spitfire Ti
Fairlight Strael
Old
Canyon Ultimate SLX 6.7kg (crashed)
Tantan GR039 7.2kg (sold)
bluewhalejack
by bluewhalejack
why grx hoods rather than ultegra, any comfort level improvement?
kroem
by kroem
bluewhalejack wrote:
Sat Feb 05, 2022 5:22 am
Idk, just really like the ergo :)
Current
P-X Spitfire Ti
Fairlight Strael
Old
MrCurrieinahurry
by MrCurrieinahurry
Nice work bere
Basso Diamante super record EPS 12
BMC slr01 ultegra Di2
kroem
by kroem
MrCurrieinahurry wrote:
Sun Feb 06, 2022 8:02 am
Nice work bere ImageImage
Thank you much! :)
Current
P-X Spitfire Ti
Fairlight Strael
Old
MrCurrieinahurry
by MrCurrieinahurry
Yea I wish I had those sort of skills.
kroem
by kroem
Well... that's the end of it.
Current
P-X Spitfire Ti
Fairlight Strael
Old
MrCurrieinahurry
by MrCurrieinahurry
are you ok?? What happened?
kroem
by kroem
Wed Mar 23, 2022 2:21 pm
ImageImageImage are you ok?? What happened?
Crashed down a decent on Gran Canaria. I was _very_ lucky and could walk away with some bruises and scratched arms/legs etc. So I'm happy it all turned out "ok". Bike, not so much...
Current
P-X Spitfire Ti
Fairlight Strael
Old
scant
by scant
you can get carbon frames repaired. its not a total loss
MrCurrieinahurry
by MrCurrieinahurry
I smashed my bmc like that got it repaired and it's as good as new
kroem
by kroem
Yeah no I know, I'm just not sure I want to... depends on if I can get something back on insurance :)
Current
P-X Spitfire Ti
Fairlight Strael
Old
naavt
by naavt
@kroem
Reviving this thread since I've just purchased a KOM chalenger set with many reserves, since I coudn't find much about it online.
Do you still ride that bike and those chainrings?
kroem
by kroem
naavt wrote:
Tue Apr 18, 2023 9:05 am
@kroem
Hi! Nah, the frame got toasted on a decent, see above :)
BUT am still using the rings, LOVE them for climbs. I'm not so used to long ascents so having 30t up front is lovely.
Shifts good/ok, even on Force AXS now which is supposedly not supported (no 13t diff)
Current
P-X Spitfire Ti
Fairlight Strael
Old
