New supercaliber 9.8 gx
Just got my project one supercaliber 9.8 gx (ordered in oktober last year)
It has been a long wait but man do i love the colour.
Colour is molten marble.
I upgrade the rims to the kovee xxx's and the kashima isostrut and sid ultimate shock and fork
Weight came in at a rather dissapointing 10.55 kg (will update with a photo of that,as well as future upgrades.
Verstuurd vanaf mijn HD1913 met Tapatalk
Upgrade time!!
Finally got around to some weight weenie'ing
Changes
Garbaruk 10/48 cassette
Xx1 chain
Xx1 dub crank with quarq powermeter on 32t chainring
Tune skyracer saddle
Darimo t1 loop seatpost (31.6mm 350length) which should probably have been 400 since I forgot to account for the saddleheigt being lower since there is no padding.
it works fine albeit just.
Switched the trek specific tubeless plastik insert for regular rim tape wich saves around 65 grams per wheel
Layed on some conti's (race and cross king in 2.2)
I know the rear tire is on backwards, I have done this since as long as I can remember.
Switched the rotors for ashima 180/160 ones
Changed some of the bolts for nice gold coated ones (Alu for the shifter, brake levers, lockout and titanium for the brake calipers) saved around 40 grams
Put on a k-edge top cap with integrated Garmin mount
Weight came in at just under 9.5 kg including the Garmin (edge 520) itself
I'm looking into a Gemini cockpit but still debating if I'm going for that or a darimo stem/handlebar combo
Changes
Xx1 chain
That's light. Nice. I would go for a Darimo cockpit, slimmer and looks so much nicer I think. Function of the IX2 stem is so good too And matching your seatpost
/jonas l
http://instagram.com/jonaslundb
Its nice saving weight but I bet you would be faster with a dropper post. Should start a new forum called fasterweenies!! Nice whip though
Yes, my thought also.cerro wrote:That's light. Nice. I would go for a Darimo cockpit, slimmer and looks so much nicer I think. Function of the IX2 stem is so good too And matching your seatpost
It is just a bummer that I have to buy new bars well since the trek bar is 35mm :/
But Gemini or darimo both had that negatieve so...
Plus the darimo option is about 150 euro's cheaper
I had a dropper on my previous bike, i live in belgium and the places were you have actual minutelong descends are so limited that i have had MAYBE 10 usefull times for it in 2 years of riding.Unbrokenchain wrote:Its nice saving weight but I bet you would be faster with a dropper post. Should start a new forum called fasterweenies!! Nice whip though
I have thought about it though and if I go riding where I can actually use it I'll get myself a reverb.
Fox just announced the 2022 Transfer SL dropper which is like 125g lighter than current model, should you want to add a dropper but minimize weight gain.
Looks nice yeah,but if I would run a dropper it would have to be external routing or wireless since I would like to switch when I feel like itMattMay wrote:Fox just announced the 2022 Transfer SL dropper which is like 125g lighter than current model, should you want to add a dropper but minimize weight gain.
I hear ya. Just took my dropper of my Supercaliber as well. Wish the AXS wasn’t such a boat anchor. Nearly 800g with battery and shifter.
