so KMC x12 works with sram axs?da123 wrote: ↑Wed Jun 23, 2021 7:00 pmCount me in for knowing this too! I've just completed two builds with Clavicula/Carbonti/SRAM AXS. Getting the front shifting sorted was a total PITA. I couldn't get it to work with the flattop chain. I've used the new KMC X12 (now compatible with AXS), which means it no longer dumps the chain over the top. I wouldn't describe it as bombproof by any stretch however
My Aethos Build
Wow light. FYI I'm pretty sure you can rotate the banjo bolt on the calpers so the brake line is more direct and doesn't have the kink in it.
@WouldLikeToBeLighter
That is a AMAZING looking build and it has dream components to boot... Envy is an understatement to what I'm feeling.
Pls update us on how she rides.
@takolino
I would love yo find out too. Btw, in my earlier thread on a 1x setup is there a way I can contact you to ask you more questions about how you modded up your strata?
Sorry for the hijack
@takolino
The braking is actually really good, better than my 11s etap using sram callipers.takolino wrote: ↑Wed Jun 23, 2021 5:23 amYou got some nice components on there. How do the sram levers handle the larger pistons of the C21? I have them paired to DA9170 and work really well.
Rene Herse 26 extralight are listed as 183g. Approved for hookless. I run mine with s tubo as well. I had the same rationale as you. I built up similar light clincher wheelset. Berd/Extralite/CB7. Same rims.
Thanks for the tyre heads up, I'll take a look, that could save quite a bit of weight
According to KMC it does. I exchanged a number of messages with them. The pre 1 Jan 2021 chains are not compatible, but apparently after that they made some changes to make it work with SRAM AXS.p3p3nko wrote: ↑Fri Jun 25, 2021 4:37 amso KMC x12 works with sram axs?da123 wrote: ↑Wed Jun 23, 2021 7:00 pmCount me in for knowing this too! I've just completed two builds with Clavicula/Carbonti/SRAM AXS. Getting the front shifting sorted was a total PITA. I couldn't get it to work with the flattop chain. I've used the new KMC X12 (now compatible with AXS), which means it no longer dumps the chain over the top. I wouldn't describe it as bombproof by any stretch however
