Avenger A6 Evo, Black-Inc Fifty tubs. 6,2 kg
This is my Avenger/Hongfu A6/FM69 with Campagnolo Super Record made 1 x with a J&L Narrowwide Chainring. Most of the components are soursed used, the Bontrager XXX Lite seatpost I found on Facebook Marketplace as the FSA SL-K bars and the AX Lightness Leaf sattle and Rigid Stem on Ebay. Changes to be put in to place is, a Sram Red Crankset, with a Digirit Chainring, to lose some more weight. I also have a set of 30mm Carbon wheels for it, with those the weight is 6,086 kg build list on request, but not with weights on all components.
Looks great!
How do you like the j&l narrow wide chainring? How long was the shipping?
Thanks!
Thanks!
- onemanpeloton
Looks great. Keen to hear your thoughts after putting some miles on it
2020 Trek Boone
2017 Merida Reacto
2017 Trek Superfly AL
2017 Merida Reacto
Looks great! Love black bycycles.synthesis wrote: ↑Wed Mar 03, 2021 3:46 pmThis is my Avenger/Hongfu A6/FM69 with Campagnolo Super Record made 1 x with a J&L Narrowwide Chainring. https://casinosik.in/ best casino online Most of the components are soursed used, the Bontrager XXX Lite seatpost I found on Facebook Marketplace as the FSA SL-K bars and the AX Lightness Leaf sattle and Rigid Stem on Ebay. Changes to be put in to place is, a Sram Red Crankset, with a Digirit Chainring, to lose some more weight. I also have a set of 30mm Carbon wheels for it, with those the weight is 6,086 kg build list on request, but not with weights on all components.
On my previous ww build I used these brakes once and they were really inadequate for any kind of slope, had to pull really hard on them and you get meagre power in return; I'll say you should definitely sell it.
I had the carbonic pulleys too; after a while the body and the bearings cartridge became loose and separated and the chain keep falling off it because of that, hope yours lasts longer!
Sent from my SM-A125F using Tapatalk
