kppolich's Tarmac SL7 Pro (7.48kg/16.5lbs)
Movin' On Up
Build Details:
Frame: Specialized 56cm Tarmac SL7 Pro
Bar: S-Works Aerofly ii 42cm
Stem: Specialized SL7 110mm
Saddle: Fizik Arione R1 Open
Shifters: SRAM eTap HRD
Brakes: SRAM eTap HRD Flat Mount
FD: SRAM eTap
RD: SRAM eTap
Wheelset: Roval CLX64
Cassette: SRAM XG1190 11-26
Crankset: SRAM Red eTap 53/39 Quarq DZero, 170mm
Bottom Bracket: Kogel BSA30
Chain: SRAM Red22
Placeholder Pic:
All of the parts from this, with the Tarmac SL7 Stem and Aerofly ii bars on the new frameset.
Initial Weights (grams)
Frame (56) 1007
Fork (uncut) 422
Expander Plug 28
Seatpost 192
Seatpost Wedge 27
TA 69
Cages 80
Stem + Mount 220
Headset 58
Top Cap 12
Headset Spacers 31
Parts are here:
42cm Aerofly II's - 243g
Kogel BSA30 BB - 87g
Ready to build
7.55kg or 16.66 lbs as pictured.
I will fix the saddle angle and eventually cut the steerer. It also needs bars taped and brakes bled but I'm waiting on a 110 mm stem to come in so the brakes aren't connected. This shouldn't be a problem for trainer duty while Mother Nature comes around in Wisconsin.
Overall, pretty cool bike. Cable routing was nice, and it came out a little lighter than my SL6.
Pics:
Still going to wait for the 110mm stem before I trim any brake lines even though I heard others have switched between 100 and 110mm without an issue
Better build pic:
Got the SL7 bled and bars wrapped. Still need to figure out position, final saddle choice, and final wheel choice. Overall, super happy with this bike so far!
3D printed mount arrived, Only bummer is the stock cap screw with the SL7 is too short (11.8mm) to reach the sled nut. I believe this needs to be a 16mm cap screw.
Stock Mount:
Really nice experience with this Shapeways 3D printed out front mount so far. It plays really nice with the Garmin and Bontrager Ion Pro RT. Only thing I had to purcahse was a longer M4x16mm bolt since the one that came with my original SL7 mount was only 11mm long.
Local shop hooked it up with the stem swap. 100mm for a 110mm. Swapped my 100mm specialized for a 110mm s-works. They actually gave me an extra 100mm with the frameset so now I have both 100 and 110 stems. I have black titanium bolts on the way, but this one came with the stock specialized Ti bolts.
Also arrived: S-Works Power Arc 143mm which I'm pretty pumped to try out. I rode a 155 Power last night and it was OK compared to my Arione R1 Open.
16.92lbs as shown
CLX 50's should be here next week to replace the CLX 64's
Pics!
Build Details:
FD: SRAM eTap
RD: SRAM eTap
Chain: SRAM Red22
Placeholder Pic:
Frame (56) 1007
Fork (uncut) 422
Expander Plug 28
Seatpost 192
Seatpost Wedge 27
TA 69
Cages 80
Stem + Mount 220
Headset 58
Top Cap 12
Headset Spacers 31
Parts are here:
Ready to build
Pics:
Better build pic:
Stock Mount:
16.92lbs as shown
Pics!
Beautiful bike, and great to see one in white.... but I really can't fall in love with that handlebar... looks like a spaceship handlebar. I would choose a nice looking aerobar..
Awesome build and jealous of your basement !
Sworks Tarmac SL8 - 7.09kg
LS Ultimate (7.89kg), Tarmac SL7 (7.56kg), Aethos (7.00kg), Venge (7.59 kg), Roubaix Team (7.53 kg) - Sold
That computer mount looks great Kyle!
Nice build! What saddle height is this?
787mm from Top of Saddle to Center of BB.
Thanks! Im guessing you have more than 1cm clearance to min insert?
Yep, probably 7cm of seatpost not showingDanielNorway wrote: ↑Wed Feb 03, 2021 4:42 pmThanks! Im guessing you have more than 1cm clearance to min insert?
Ok, so max saddle height is around 855mm?
Max Saddle Height on a 56cm with stock seatpost is 835mm.
That is shown below and measured from the Center of the BB to the top of the Saddle Rail Clamp.
If your saddle rails are higher or lower your actual top of saddle measurement will be different.
