Engineering bicycle part by part
MrCurrieinahurry
by MrCurrieinahurry
Komarov wrote:
Lucendi wrote:
Sat Dec 25, 2021 5:03 pm
Wow, the engineering skills in this thread are seriously impressive!
I'm just starting :D
Basso Diamante super record EPS 12
BMC slr01 ultegra Di2
Kimmoth
by Kimmoth
Fully siiick, bro!!! - as some Middle Eastern and Mediterranean Aussies like to say :D
Hey, I don't suppose there's any chance of you doing a bar/stem?
Probably even less chance of it being an Aeronova copy, right...?
And although 110/38 is probably the first size you'd make, I guess I wouldn't be able to stick the PCB from an A junction inside the stem, huh...
Komarov
by Komarov
Kimmoth wrote:
Thu Feb 03, 2022 8:48 am
If you are in Melbourne - check Della Bici bikeshop, they have almost everything I've made in stock I guess :D
And there is a chance of making bar-stem combo :wink: since I've made a modular mould for road handlebar - I'll have to change only 2 parts of the mould in the middle and leave the drops as they are. But it will most probably be 42cm wide.
But have to finish tests first - made 8 prototypes already and still not 100% satisfied. Came to the state where I've decided to make my own carbon fiber prepreg to get the parts right :)
P.S. Why tf would I copy Aeronova?)
Komarov
by Komarov
Btw, I've been doing a batch of side projects recently along with handlebar testing
D-shape steerer tubes, 27,2/31,6mm tubes for DIY seatposts, little tubes for wheel axles, seatpost designs:
Hope to see everything as finished products very soon
Kimmoth
by Kimmoth
Komarov wrote:
Thu Feb 03, 2022 3:56 pm
Have you used one? Aside from looking the absolute tits, it's as ergonomic as it gets. The downward slope on the tops fits under the hands beautifully, and the humps at the end of the tops catch your hands just so when shifting positions, adding comfort and safety, not to mention making the phantom aero bar position way less dangerous.
After using this shape, I'm completely uninterested in any other bar.
Juanmoretime
Administrator
by Juanmoretime
I too will praise the Aeronova and Aerotunda, LTD naturally. I have the first on my Liespeed T3 disc and need less drop siince the T3 has a longer headtube tham my Blue AC1, the latter has the Aerotundo. 203 grams for the Aerotundo LTD and 193 grams for the Aeronova LTD. Paired with a MFCK Stem on both. Stems weigh 71 grams for the T3 and 73 grams for the AC1.
C36
by C36
It’s quite a polarising bar that has its good parts but… quite a long reach for actual stds, the top section is not confortable if you do long climbs on the top part and the “angle” in front of the hoods is not really usable. Maybe not a first bar to do…
Komarov
by Komarov
C36 wrote:
Sat Feb 05, 2022 5:18 pm
Yeah, exactly!
Aeronova is more of an aerobar, so it also has to be heavier to compensate lack of stiffness of the low profile and for now we wanted to make a relatively lightweight bar.
Next one will be aero (after bar-stem combo 8) )
Also aero gains will be so insignificant (mental aero gains can be more significant though :D ) for the majority of riders so its more of a narrow-niche product
Kimmoth
by Kimmoth
I expect a bit of give in an aero bar... As long as the stem is beefy I don't notice the flex soaking up any power.
Komarov
by Komarov
Kimmoth wrote:
Thu Feb 17, 2022 5:49 am
I dont know for other brands, but I'd make aerobar as stiff as round one (flexy parts also usually have less strength due buckling so wont go on a thin ice here), but that will mean weight penalty.
So aerobar will fill the same in terms of flex, just heavier
Perp
by Perp
Used the 3d printed saddle for a few rides now (on trainer). Very comfortable. I stand to give my legs a change of position rather than my butt needing a break. Gets a bit sore 2.5hr in, but I rarely ride the trainer that long. I haven't had any saddle that doesn't give discomfort after 2.5hr on a trainer.
Came in 120g
Komarov
by Komarov
Perp wrote:
Sat Feb 19, 2022 3:48 pm
Came in 120g
Hi!
So happy you liked the saddle, you probably have it 155mm because they were developed a little later so around 5g lighter for now (I'm finishing big mould for 143mm ones which will make them a bit lighter too).
I was also thinking about seatpost-3d printed saddle combo with some minimal adjustment possibility
RDY
by RDY
Komarov wrote:
Sat Feb 05, 2022 8:44 pm
Yeah, exactly!
Bar tops are pretty worthless on round bars, if you have large hands. Flat aero bars are great. I never bother using the tops on round bars. Uncomfortable and pointless.
jpeterson1012
by jpeterson1012
I want a set of super light high-riser bars with the horizontal bar in the middle, like the whisky milhouse but even more rise, for my beach cruiser/shit day bike
drumjdds
by drumjdds
Impressive attention to detail! will definitely consider when upgrading in the future. thanks for sharing
