2020 Emonda SLR Weight Loss
drock79
by drock79
Took delivery of my 2020 Emonda SLR late last October. It was ordered with Sram Force AXS and rode super well. Yet I wanted to go ahead and see how much weight I could remove if I went Sram Red 22 Mechanical.
Here are some pictures and the weight of the bike before I began my project
7194 grams w/o pedals and cages
Components List AXS
Shifters: 476 grams
Calipers: 346 grams
Sram Centerlock Rotors: 234 grams
Front Derailleur: 199 grams
Rear Derailleur: 325 grams
Force Crankset 48/35 172.5: 807 grams
Force Cassette 10-28: 266 grams
Force Chain: 259 grams
Bontrager Montrose Elite Saddle: 220 grams
Bontrager Pro V3 TLR wheels: 1590 grams
Bontrager R3 Clinchers: 430 grams
Bontrager Tubes: 130 grams
Bontrager XXX 420mm Bars: 176 grams
Bontrager Pro Blender Stem 100mm: 132 grams
Seat Mast Cap: 130 grams
I didn't weigh the frameset but Trek claims 690 grams for an unpainted 56cm which is what I have and the fork is also claimed to weigh around 350 grams, add a few hundred grams for the pink paint & bearings and I estimate the frameset at 1300 grams.
Here's the updated bike with Red 22
5896 grams w/o pedals and cages
Component List Red 22
Shifters: 303 grams
Spyre SLC Flat Mount Calipers: 308 grams
Ashima Ai2 Rotors w/ti bolts: 160 grams
Front Derailleur: 74 grams
Rear Derailleur: 147 grams
Crankset 50/34 172.5: 579 grams
Dura Ace 9100 Cassette 12-28: 204 grams
FSA 11 Spd chain: 232 grams
Selle Italia SLR Saddle: 129 grams
Farsports Tubular Wheels with Extralite Hubs: 1026
Tufo S3 Lite: 430 grams
Effetto Mariposa Tubular Tap: 56 grams
Don't think I forgot anything. If I did I'll update the thread. Enjoy
LewisK
by LewisK
Great weight saving and I actually think it looks better with Sram Red Mechanical!
PoorInRichfield
by PoorInRichfield
Dang... already crazy light and I can see even more places for further trimming...
  • Cut steerer tube... unless of course you need the bars that high
  • New thru-axles that don't have the lever attached... My Domane axles have a removable lever that is an Allen wrench so it doesn't stay on the bike
  • 140mm brake rotors... If you're not a heavy rider, going from 160mm rotors to 140mm won't likely matter (it didn't for me). You'll save the rotor weight and be able to remove the rear caliper spacer
  • Delete valve caps... Not sure what value valve caps add to Presta valves :?:
You might need to carry an anchor in your pocket when riding 'cause if you get off the bike, it might float away! :shock:
drock79
by drock79
LewisK wrote:
Fri Oct 02, 2020 3:21 pm
Thanks, I do too.
drock79
by drock79
PoorInRichfield wrote:
Fri Oct 02, 2020 4:06 pm
I need the stack
I will get thru axles down the line, need to give the pocket book a rest for the moment
I'll stick with 160's since I'm 205lbs
Love the pink valve caps, I'll suffer thru the 1.5 gram penalty ;)
Can't wait until I can take her out on some serious climbs.
FactoryMatt
by FactoryMatt
titanium brake cable clamp and stemp clamp bolts. XG1199 cassette.
RyanH
by RyanH
Moved to introduce yourself. Nice bike btw.
drock79
by drock79
RyanH wrote:
Fri Oct 02, 2020 10:15 pm
Oh, thanks, sorry for not following etiquette.
tonchy
by tonchy
Great looking bike and nice weight savings. :)
FactoryMatt wrote:
Fri Oct 02, 2020 6:09 pm
You probably meant XG1190 cassette. :thumbup:
easyv
by easyv
Interesting that despite all of the technology that SRAM has baked into it's two generations of ETAP / AXS, there's still something refreshingly clean about "old school" mechanical Red 22... Doesn't hurt that it's still one of the (THE?) lightest overall gruppo out there...
FIJIGabe
by FIJIGabe
Very nicely done. I would second the thru-axle recommendation as your next step. Personally, I went with the Robert Axle Project T/A's for my Crockett, and haven't looked back. They're lightweight and very stable. You likely already carry a multitool, so you free up a bunch of weight by omitting the handle.
drock79
by drock79
FIJIGabe wrote:
Mon Oct 05, 2020 1:12 am
Thanks!
And I've already looked into those thru axles. They're on my Christmas list :)
drock79
by drock79
Time to resurect this post with some updates. I was able to shed a few grams with new thru-axles and an Extralite stem
Old Bontager thru-axles
New Robert Axle thru-axles
Old Bontrager stem
New Extralite stem
Update total weight
One third of a pound lost. Next up on the gram shaving schedule are the Growtac Equal Brakes to hopefully save another 40 or so grams. Can I get his Project One to 12.5 lbs?
Nixster
by Nixster
Praxis rings on the cranks will save you 25g or so. XG1190 cassette is worth 40g. Glue the tubs rather than tape will be lighter, how much kind of depends 😀
Nixster
by Nixster
Oh and go with SRAM red chain when this one wears out, won’t be lighter but it will shift better and be quieter on the SRAM cassette 😀
