Cervelo Aspero - Sub 7kg Goals UPDATE 7.3Kg
Update new build details below..
Hey all!!
I figure its time to provide some shots of what I am working with so far:
Cervelo Aspero
Black/ Gold
Size 51cm
Weight: 7.775KG/ 17.1 Lbs.
The Build with weights:
Frame, Fork, Bottle Bolts and Seat Clamp: Cervelo Aspero 51CM - 1516g
Headset: Cervelo Headset is42/is52 - 62g
Headset Nut: Cervelo Compression Plug - 44g
Bottom Bracket: BBinfinite Ceramic DUB - 110g
Thruaxles: J&L TA Front - 22g/ Rear 26g - 48g
Shifters: SRAM Force AXS Shifters - 476g
Calipers, Hoses/ Flat mounts: Scram Force AXS Calipers/ Hoses, Mounts - 330g
Rotors: SRAM Centerline X 160mm Rotors - 234g
Locknut: Shimano Deore Rotor Lock Nut - 21g
Front Mech: SRAM Force AXS F Derailleur w/ Bat - 181g
Rear Mech: SRAM Force AXS R Derailleur w/ Bat - 325g
Crank Arms: SRAM RED/ Quarq AXS Arms 165mm - 337g
Power Meter: Quarq DUB Spider + 10 Bolts - 171g
Chainrings: SRAM FORCE AXS 48/35 - 180g
Cassette: SRAM FORCE AXS 10-33t Cassette - 267g
Chain: SRAM RED AXS Chain - 249g
Wheelset: Easton EC90 SL 700c w/ Tape & Valves - 1464g
Tires: Panaracer GravelKing Slick 32mm - 580g
Handlebars: Easton EC90SLX 38cm - 190g
Stem: UNO w/ Ti Bolts 90mm - 95g
Seatpost: Elita One Seatpost - 137g
Saddle: Selle Italia SLR Superflow Ti316 - 180g
Bar Tape: SupaCaz Bar Tape - 90g
Spacers: Spacers: 10mm x2 Aluminum - 14g
Sealant: Orange Seal Endurance, 30ml per tire - 60g
Pedals: Shimano PD-ES600 - 282g
Cages: Chinese Carbon - 44
Head Unit: Wahoo Bolt- 62g
Head Unit Mount: Wahoo Easton Mount - 25g
Hose Dampner for rear brake hydrolic hose: 5g
Total Weight (g): - 7779 KG
Total Weight (Lbs.): - 17.15
I am very happy with it so far; its definitely a quiver killer for me!... I had a 48cm Aspero but never got comfortable on it as I felt to big over the bike..
Future WW goal is to get it to below 7.2KG/ 16Lbs.
I am thinking changes/ upgrades are as follows:
Farsport wheels sub 1250grams
Lighter 25/28mm Tubeless tires
Lighter compression nut
Lighter bar tape
Lighter Wahoo mount
If you have any suggestions or recommendations I am all ears
Hey all!!
Cervelo Aspero
Black/ Gold
Size 51cm
Lighter bar tape
Lighter Wahoo mount
Lol, yours is sweet man.. tell me more abut the direct-mount hanger from paragon? is it longer, stronger, lighter give you more gear range?icantaffordcycling wrote: ↑Fri Sep 25, 2020 9:31 pmDang, I just got flexed on, I had the nicest black/gold 51 aspero on ww for all of 3 hours. Sick build.
Update and Weight savings: 432grams to delete to hit my goal...
Update new build details below (road Mode)..
Okay so put some new bits on and took some stuff off..
Added:
44T Xsync Chainring
Speedplay Zero Stainless pedals
Origin8 Cork Tape
Removed:
Front derailleur (back to 1x as 2x was problematic)
48/35 Charinrings
SupaCaz Bartape
ES-600 Pedals
Frame, Fork, Bottle Bolts and Seat Clamp: Cervelo Aspero 51CM - 1513g
Rear Mech: SRAM Force AXS R Derailleur w/ Wolftooth Roadlink w/ Bat - 341g
Chainrings: SRAM Xsync 44t - 80g
Cassette: SRAM FORCE AXS 10-36t Cassette - 311g
Bar Tape: Origin8 Cork Tape - 40g
Spacers: Spacers: 10mm x1 Aluminum - 6g
Pedals: SpeedPlay Zero Stainless - 209g
Head Unit Mount: Wahoo Mount - 25g
Total Weight (g): - 7432 KG
Total Weight (Lbs.): - 16.38
If you have any suggestions or recommendations I am all ears need to shave 432 grams
Added:
44T Xsync Chainring
Origin8 Cork Tape
Removed:
48/35 Charinrings
SupaCaz Bartape
ES-600 Pedals
Thanks for that.. The link was for the thumbnail not the full size image.. Check above now as it shuld be fixed..
The saddle bag is a Speedsleev Ranger S model... Really lite and holds a lot suprsingly
Titanium axles for the pedals, lighter seatpost clamp, garbaruk chainring, xtr rotors, and a lighter saddle are the cheap/easy ones I spotted. Everything else would get expensive.
Quick question - what type of riding do you do with this bike? I'm guessing it's more of an all road setup given the gearing and tire choice instead of gravel.
icantaffordcycling wrote: ↑Wed Oct 21, 2020 4:24 amTitanium axles for the pedals, lighter seatpost clamp, garbaruk chainring, xtr rotors, and a lighter saddle are the cheap/easy ones I spotted. Everything else would get expensive.
Thank you for the suggestions.. I will look into them.. However, who makes a lighter seatpost clamp that fits the Aspero?
Yes this is my everything bike right now.. I have 2 wheelsets:
Road mode:
44T CR 10/33 Cassette
EC90SL Wheels with soon to be Panaracer Race tubless once they are in stock and will drop 100 grams for the pair compared to the GK Slicks in 32mm
Lite Gravel Mode:
44t CR w/ 10/36 cassette
EC90AX wheels with GK SK 38mm
SpeedPlay SYZR Pedals
Heavy Gravel Mode:
40t CR 10/36 Cassette
Yep they sure do.. I dont know why, but people never mention that GK tubeless tires are the lightest per size across all the ranges compared to nearly every brand.
My GK Sk 38mm Tan sidewalls weigh 858g pair.. For comparision I have a pair of Strada Bianca 36mm Slicks and they weigh 878g a pair
what saddle would be inexpensize in the 100g range?
There are plenty of chinese ebay jobbies that would do the trick.
Saevid are very reasonable and very light. Berk were doing some 20% discount thing not that long ago which made the Lupina/List a good price. I just picked up a San Marco Mantra Superleggera for £158.99 (114g)
Depending on your DIY skills, you could pick up a second hand Selle Italia SLR carbonio/flow and strip the padding.
If you want to drop some weight and stay with slick 38's, the RH Barlow Pass EL's are 700g for the pair (reported)gSporco wrote: ↑Wed Oct 21, 2020 4:49 amYep they sure do.. I dont know why, but people never mention that GK tubeless tires are the lightest per size across all the ranges compared to nearly every brand.
2020 BMC TeamMachine SLR 01
Sweet Ill have to check them out..RobJ wrote: ↑Wed Dec 09, 2020 11:24 pmIf you want to drop some weight and stay with slick 38's, the RH Barlow Pass EL's are 700g for the pair (reported)gSporco wrote: ↑Wed Oct 21, 2020 4:49 amYep they sure do.. I dont know why, but people never mention that GK tubeless tires are the lightest per size across all the ranges compared to nearly every brand.
I will update this post as I got the Aspero down to 7.3KG in All Road mode with 32mm GK Slicks. So I am getting close to breaking 7KG.. I think it will be hard to break 7kg with 38mm tires in gravel mode.. That will require some super lite wheels..
