I'll add some better full-bike photos when the lighting is good/I go out with my camera.
The next step in my journey towards practical weight weenie-ing is converting this to 1x. You may wonder, why go 1x11 50T on a bike that's perfect for climbing? To which I will answer, "find me a hill in Chicago please."
Plus, 1x is just more user friendly. The SRAM+Campag front shifting on this bike is utter GARBAGE. I never use the small chainring over concerns of it dropping the chain, and that's with almost no power.
The 1x setup will probably be this:
1. FSA Ceramic PF30 BB - 50g (-28g, 75USD)
2. InColor Skypivot Cranks + Spider - 327g (350 USD + shipping)
3. Fibre-Lyte or Lightworks (eBay) Carbon Chainring 50T (Both ~130 USD, Fibre-Lyte is well known, but Lightworks has a narrow-wide version which Fibre-Lyte doesn't) - 60g
4. KCNC Short Chainring Bolts - 6g
5. Total Crankset weight = 393g (-232g)
6. Remove FD+Chain Catcher + Hanger + Bolts (-99g)
7. Remove FD Shift Housing + Cable + Barrel Adjuster (estimated -35-40g)
8. Remove Shift Paddle + Ratchet Internals from Red Left Shifter (estimated -30g)
9. PYC SP-1101 Chain (-14g)
9. Estimated 1x Savings: ~439g, meaning the new goal would be 10lbs, of course
Now for the gallery
White spokes are pretty eyecatching!
Get pretty scared every time I work on this stem... plus, the printed manual I received when I bought it says 3Nm for the HB-Clamp, now they updated it to 2Nm on their website... Always did 3Nm, am I in danger?
I hate the "new ergo" brake lever instructions FSA gave. They looked like shit and the hoods actually pointed slightly down when done according to their "optimal mounting position." Straight in the bin it went.
These poor Ciamillo brakes from 2006... They barely open wide enough for these 25mm rims. I get bare minimum brake lever travel even with the tire release tab flipped to the "open" position.
Some heavy tuning was done on this saddle. It was bare carbon to start at 82g, ended up at 62g.
Rope Spokes.
An aluminum mini brake noodle was used to shorten the RD cable run. The frame was also designed to have the housing run all the way to the bottom bracket cable guide, but a 4mm-5mm stepdown ferrule was used to create a DIY cable stop, along with some inner sheathing to protect the frame innards from cable abrasion.
Can't wait for the 1x conversion!
