Basso Diamante ultegra di2
- MrCurrieinahurry
- Moderator
Excuse the bad pictures..
Build list
Basso Diamante rubin red 56cm
Shimano ultegra 8050 compact 50/34 di2 172.5 with handlebar junction
Basso integra stem/bar 44x120
Custom rubin red spacer + Italian flag spacer combo.
Basso carbon seatpost
Basso integra comp mount
Garmin to wahoo adapter
Wahoo roam
Speedplay ti pedals with ti butterfly plates
Supercaz carbon gold fly cages
Supercaz bar tape
Selle italia slr saddle (berk lupina will be coming)
Swiss top pad holders and pads depending on wheels
Wheels
Reynolds 46 aero clinchers (zipp skewers)
Hunt race alloy clinchers
Strada stillieto alloy clinchers
Vittoria butyl inner tubes
Vittoria corsa 25 tan
Sent from my MAR-LX1B using Tapatalk
Build list
Wahoo roam
Supercaz bar tape
Wheels
Last edited by MrCurrieinahurry on Sat Oct 03, 2020 2:06 pm, edited 1 time in total.
- MrCurrieinahurry
- Moderator
Back with the hunts on.
Lovely colours going on there, the Italian spacers set it off a treat. Definitely looks better with the Reynolds!
Cannondale SSEvo3 'Atticus' - 7.2kg
viewtopic.php?f=10&t=161634
Cannondale Systemsix ’Dante’ - 7.7kg
viewtopic.php?f=10&t=167144
I've picked up the same frame and groupset. I wanted to tidy up the di2 because the cable going in to that down tube cable stop isn't particularly tidy. On the 2020 frame set it runs in through a hole in the brake stop. There's plenty of material on the brake stop so you can cut a small notch in there and run the cable in through next to the brake cable.
- MrCurrieinahurry
- Moderator
Oo I like this idea. Tbh I don't really like those two cable entry points on the down tube would be nice if they were removed carbon added and painted over at some point.
- MrCurrieinahurry
- Moderator
Hey man thanks for the heads up on the cabling good idea I was thinking of running Jagwire cables too at some point to try and get the cables neater as they do bother the hell out of me.Slack wrote:I've picked up the same frame and groupset. I wanted to tidy up the di2 because the cable going in to that down tube cable stop isn't particularly tidy. On the 2020 frame set it runs in through a hole in the brake stop. There's plenty of material on the brake stop so you can cut a small notch in there and run the cable in through next to the brake cable.
What's your build list looking like?
- MrCurrieinahurry
- Moderator
@slack wouldn't the seatpost get in the way of the di2 wire tho?
Adam
Adam
- MrCurrieinahurry
- Moderator
@Slack
- zappafile123
Lovely build, could you give us a ride report?
FactorOne|SartoSeta|StorckF.3|Enigma EliteHSS|SworksSL6|ColnagoC60/V3Rs|DeRosa Protos|BianchiXR4/2|BMCSLR01 16|Cdale EvoHM|Focus IzMax|RidleyHe SL/SLX|BH Ulight|BassoDiamante|Scapin DyseysS8|TimeRXRS/ZXRS|TCR SL|RidleyNoah|Look585|CerveloS5/S3
- MrCurrieinahurry
- Moderator
Of course!
- MrCurrieinahurry
- Moderator
What you want to know?zappafile123 wrote:Lovely build, could you give us a ride report?
