Basso Diamante ultegra di2
- MrCurrieinahurry
- Moderator
My bmc should be back on the road soon and I'll compare them properly
Sent from my MAR-LX1B using Tapatalk
- MrCurrieinahurry
- Moderator
When the standard 8 vertices rectangular prism is just too heavy.
- MrCurrieinahurry
- Moderator
Looks beautifuly made. Had it Custom painted to match my basso and has come in at 90 grammes so super happy...
Thanks for the idea Slack, I just did this and looks cleaner now.Slack wrote: ↑Sun Oct 18, 2020 6:30 pmI've picked up the same frame and groupset. I wanted to tidy up the di2 because the cable going in to that down tube cable stop isn't particularly tidy. On the 2020 frame set it runs in through a hole in the brake stop. There's plenty of material on the brake stop so you can cut a small notch in there and run the cable in through next to the brake cable.
2020 Colnago C64 Mapei-SR12 EPS-WTO 60
2021 Basso Diamante SV-SR12 Disc EPS-WTO 60
2023 Colnago G3X-SRAM AXS Force-Levante
- MrCurrieinahurry
- Moderator
I'm gunna do the cable mod when I'm free next to pop to the shop.. Did you guys have to change the di2 cable for a longer one do you know?
I'm excessive but I used to run a shorter cable from bar into down tube. Then put an extender then a cable down to junction. It that was so I could take the front off for various travel.
Otherwise I always used the longest di2 cable regardless to be safe. 1000-1200mm with 40mm bars and bar end junction.
Just ride ..
- MrCurrieinahurry
- Moderator
Well vred superlight latex tubes installed 94 grammes saved. Was going to whack the corsa controls on but hadn't realised the hutchinsons are only 384g for the pair where as the corsa controls were 547g.
So they are back hanging up.
- MrCurrieinahurry
- Moderator
- MrCurrieinahurry
- Moderator
Hahaha deof ain't my gate mate lol
