Cannondale SuperSix Nano Black Inc [3.96kg]
Introduce your new bike! Introduce yourself! Use metric.
RouarierDmer
by RouarierDmer
Cannondale spindle, and SiSL2 cranks in 172.5mm that I had anodized in black for a more stealth look. I was never a fan of the white laser etched logos
Tune Golden Rocket - 5.66kg | viewtopic.php?f=10&t=161531
Cannondale Supersix HM Tri - 4.63kg | viewtopic.php?f=10&t=161698
mike
Resident Pro
by mike
excellent job with the stripping of the paint. i can see this project being 8 poinds
ultyguy
by ultyguy
Only a complete lunatic would attempt this (Rob)
RouarierDmer
by RouarierDmer
mike wrote:
Fri Apr 05, 2024 1:03 pm
Thanks. I think 8 pounds will be complicated to reach unless I put on these paper thin Tufo elite 125g tires, which I might do at some point for fun.
RouarierDmer
by RouarierDmer
The BB30 standard shell is known for developping creaking issues due to poor bottom bracket manufacturing tolerances from Cannondale, as demonstrated by Hambini. In short, the internal BB diameter can vary significantly so the bearings are likely to be moving inside the BB shell. To minimize that by filling the gaps, I applied some commonly used retaining compound: loctite 648. I combined that with original NTN bearlings size 6806 LLB 30x42x7, known for their high quality and tight tolerances. Not the lightest but smoothness is key in that area. Make sure you are not buying counterfeit ones, so you need to have the QR code Authenti Bear on the box to guarantee its authenticity.
mike
Resident Pro
by mike
RouarierDmer wrote:
Mon Apr 08, 2024 9:43 pm
i would not use the track tires even for a short ride as they puncture too easily and cost a fortune (over $125 per tire). the veloflex records are more puncture resistant.
minimini
by minimini
I'm looking forward to it. :D
I made it in 2014 weighing 3997g.
There are many lighter bike parts now, so it will be easy to make them.
RouarierDmer
by RouarierDmer
minimini wrote:
Mon Apr 15, 2024 9:09 am
Very impressive build, especially with paint and 2-by drivetrain
RouarierDmer
by RouarierDmer
Bottle cage, brake pads, derailleur hanger and cable guide
ultyguy
by ultyguy
This definitely needs to be ridden up the Croisette from Le Coin in under 20 minutes
RouarierDmer
by RouarierDmer
Shortened the Darimo seatpost, final weight of 65 grams
RouarierDmer
by RouarierDmer
Headset dustcap weighing literally... nothing
RouarierDmer
by RouarierDmer
PYC chain, 196g. Good thing when you are running a one by groupset with a 28x28 development, is that you can significantly shorten the chain.
RouarierDmer
by RouarierDmer
I tried to make heat shrink hoods, which was a fun and light side project.
But the result proved not to be aesthetically pleasing (to say the least) and the hoods were sliding, so in the end went back to the original SRAM hoods
RouarierDmer
by RouarierDmer
Trimmed bottom bracket cable guide
