My Pivot Mach 4 SL build
Forgot to react on the pedals, sorry. The Xpedo M-force were lacking in clipping in and not very supportive, but I was ‘used’ to the small platform. The CXR ones were better at clipping in but had a less secure hold. So away they went, followed up your advice and installed the heavier Look’s. What can I say, I like them a lot and the support really is very nice. Also when temporarily not being clipped-in it is less sketchy due to the larger area. Clipping in is very good too. So, thanks for the tip, appreciated!DanW wrote:Looking great! I hope my comment about Xpedo not being supportive didn't get in your head! But I do genuinely believe that the Look are way more supportive.
You have to be getting close to a settled build after all those $$$
Piccola Carbon with C22 calipers, delivered today, bought in July 2020 at r2-bike.
Weight complete set, uncut, incl alu backed pads, excl caliper bolts: 144,8+161,8+11,1+19,4+3,6=340,7g
The supplied caliper bolts are a bit heavy (19,4g), 4 Extralite titanium caliper bolts weigh approx 9g.
Brake line length front/rear, excl fittings: 89/168cm, thus 100cm filled brake line weighs approx 21,5g.
- robbosmans
- Moderator
- Contact:
Definitely my dream brakes!
It is called Lazybone, I found it on Shapeways:
https://www.shapeways.com/product/TLC4F ... armin-edge
For functionality (staying in place when mounting/unmounting your Garmin and when pre-loading the headset) the k-edge is better though, but the weight of the Lazybone can’t be beat.
A small Hopp update for the Piccola’s, saving another 9,8 grams. Looks better too (all black). Also has the advantage that with a shifter/dropper lever attached you can still adjust the brake lever position (bolt head on top instead of behind matchmaker).
Also installed an RWC needle bearing kit on the top eyelet of the DPS. Better small bump sensitivity. Not in same league as the temporary McLeod I used (heavier than DPS), but noticeably better than with the original bushing kit from Fox installed, which was a very tight fit on this shock. Weight penalty is 11 grams.
