The Grower: Time Fluidity
RichTheRoadie
Tinker, Taylor, Tart
by RichTheRoadie
I didn't put a thread up about this when I first got it because it was only ever intended to be an interim frameset. However, the bike that is filling in for has been out of action for longer than anticipated, so this has seen more and more use - and, in that time, has grown on me more and more...
I had long been intrigued about these, but they were always really expensive, rarely on sale, and the earlier ones would only take 23c tyres. Whilst searching for a decent-but-cheap interim frame I found a good deal on a Look 765 frameset locally, only to then find the same place was shifting some of these at an even better price. Knowing that the later ones had better tyre clearance, I took the gamble.
Initially built with 12v Record, I spent a while getting it sorted, switching between wheels, tyres and bar tapes whilst I tried to sort a setup and look that worked for me. Eventually I settled on the stealthier look, which coincided with changing the tyres to 28c - suddenly the bike felt totally dialled and came to life; and I've been enjoying it more and more ever since. In fact I've been enjoying it so much that it is now wearing a full 12v Super Record groupset taken off of my previous favourite bike.
The rest of the build is fairly straightforward at the moment - mainly because I prefer keeping the groupset complete and also because the supplied Time seat post is quite nice, which just leaves me to put a nice stem and bar on it. I'll probably go with an Extralite Hyperstem in stealth finish eventually, but the current Covid-19 situation is making those hard to get hold of so I'm currently using a 3T stem as a place-holder.
My Time post unfortunately cracked, but is thankfully being replaced under warranty, hence the WR Compositi inline post that's on the current setup:
Build is as follows:
Time Fluidity frameset - size M (55cm top tube), 2017 model
Fulcrum Racing Speed 40C wheels with CeramicSpeed bearing upgrade (also pictured with older Bora 50s)
Veloflex Corsa 28c tyres
Full 12v Super Record groupset
Praxis BB30>Campag BB adaptor
Time carbon seatpost (WR Compositi inline post in the interim)
SQlab 612 ErgoWave Carbon saddle
3T Apto Team Stealth stem (also pictured with Paul Comp Boxcar)
Zipp SL70 Ergo carbon bar (currently wrapped in Cinelli Art Series Ana Benaroya 'Cyclops' tape)
Arudnel Mandible cages (the Time ones were too flimsy)
Weight with this setup is 7.1kg - which I'm pretty happy with given that lighter brakes, stem, cranks and wheels would easily drop that down.
If I keep it, I'd like to refinish it with a simple raw carbon, gloss clear and single colour Time logos as I don't like the design Time have used on it, but that's low priority.
Here's some more pics:
outnumbered
by outnumbered
How do you find the shifting on this bike? I looked at these a while ago and saw they have really short chainstays (shorter than campag recommend iirc), so wonder if you get any chain rubbing or problems in large ring and larger sprockets?
RichTheRoadie
by RichTheRoadie
No issues at all here.
Why would Campag recommend a chain stay length? Yes it's short (404mm) and for disc I could perhaps understand as there's chain line issues with the wider rear axle; but on a rim brake bike that's not a problem.
maxim809
by maxim809
Wow looks GREAT! Especially against those backdrops. Not sure if intentional, but you even matched the bar tape to the background.
2013 Cannondale Synapse 5 | 2014 Pinarello Dogma 65.1 | 2015 LaPierre Pulsium | 2016 Bianchi Oltre XR4 |2016 Pinarello Dogma F8
Very nice! Post a ride review whenever you think you are ready.
mike
Resident Pro
by mike
great bike! time bikes are "timeless" and quality is second to none.
ghostinthemachine
by ghostinthemachine
RichTheRoadie wrote:
Mon May 04, 2020 8:27 am
It's to do with chain angle. Shorter stays = worse angle. It's why a couple of my older race bikes can't use certain gear combinations. 12/13/14 sprockets cause the chain to rub on the inside of big ring when i'm in the small ring, if i inadvertently shift to far up the block in the big ring, it runs really quite nosily, especially with new kit. (think that's 8 speed)
We are talking ~390mm stays though. And no paint on the back of the seattube, even with 21mm tubs. (i don't ride them often!)
Clean39T
by Clean39T
Great looking bike. What do you think of the wheels? They've been on sale pretty cheap recently.. Considering a pair for my Dogma.
RichTheRoadie
by RichTheRoadie
Clean39T wrote:
Mon May 04, 2020 7:48 pm
They're very decent wheels. Ask Strongin on 'the other forum' - he's also a big fan.
mortirolo
by mortirolo
Time frame, mechanical SR12 and rim brakes.
Everything is awesome.
But those pedals. :shock: No. No. No...
Marco Pantani - Momenti Di Gloria
RichTheRoadie
by RichTheRoadie
mortirolo wrote:
Mon May 04, 2020 10:09 pm
Pedals do not maketh the bike. And they're a fit issue (I have a very wide foot, so need the stability of the wide Shimano platform), not performance, which absolutely takes priority.
At least it's not Shimano wheels on a Campag bike (or vice versa).
Clean39T
by Clean39T
There's one of these Fluidity franesets cheap on Craigslist in Seattle - if I wasn't deep down the Dogma hole, I'd jump..
Wookski
by Wookski
ghostinthemachine wrote:
Mon May 04, 2020 12:22 pm
I'm running super record with 399mm chainstays and no issues although I've never ridden in small/ small combination. Small chainring in 12/ 13/ 14 is a terrible place to be.
Wingnut
by Wingnut
Went down that road myself too...luckily I woke up and sold them, and went back to Time pedals...
majklnajt
by majklnajt
Nice ! :thumbup:
