by kgt on Sun Apr 05, 2020 8:19 am
Very nice!
The only small detail I don't like is the greenish part of the fork. I would either remove it or glue a grey stripe on top.
jlok
by jlok on Sun Apr 05, 2020 8:39 am
kgt wrote: ↑Sun Apr 05, 2020 8:19 am
Very nice!
Thanks! Yea, will spray it matt black once I got masking tape.
addictR1
by addictR1 on Sun Apr 05, 2020 7:47 pm
Looks nice... yea the green is throwing off the look of the bike.
Btw is this the right way to install the seat collar? I thought the bolt should be in the back?
jlok
by jlok on Mon Apr 06, 2020 2:37 am
The seatpost slips so I reversed the collar to see if that improves, but doesn't.
I'm going to try hair spray trick. Not sure if that would survives rainy day riding tho.
Tamu8104
by Tamu8104 on Mon Apr 06, 2020 3:15 am
Nice build, enjoy!!
Firefly Ti Road Disc
Rock Lobster Team Tig SL Disc
Santa Cruz Blur 2019
Gaulzetti Cabron Disc (Retired to the Kickr after an accident)
wheelsONfire
by wheelsONfire on Sat Apr 11, 2020 10:02 pm
jlok wrote: ↑Mon Apr 06, 2020 2:37 am
Yes ofcourse it does!
A super light carbon collar isn't going to induce that clamping force you'd need on this frame.
You should use something in alu or Ti.
https://www.controltechbikes.com/products/item/148.html
Oh, talking position of the collar, it's best to have the bolt (locking) at the side the seat mast tube slip is.
So, if it's in the rear, then it should be best in the rear. If in the front, then in the front.
Bikes:
viewtopic.php?f=10&t=156137
Open *UP* (2016.04.14)
Ex bike; Vial EVO D
jlok
by jlok on Sun Apr 12, 2020 12:45 am
Ok, advice taken and fall back to the 5-time heavier aluminum collar
jlok
by jlok on Sun Apr 12, 2020 7:49 am
I need something to take a bit more than 6Nm as the stainless steel tubing is obviously stiffer than the lightweight T1sl. I used Carbonice minimalist collar on T1sl with great effect. Darimo Sub4 max torque is 5Nm so... goodbye.
jlok
by jlok on Sat May 30, 2020 6:55 am
Covered the green strip on fork with paint and swapped to Fulcrum Speed 55 DB with Corsa Control TLR 25/28. I think it looks more proper now.
jlok
by jlok on Wed Jun 03, 2020 11:42 am
Yea, definitely. I want to use Pro Race Comfort tape again for the grip when I wear the current Supacaz. The Bling tape is a bit slippery.
Yemble
by Yemble on Thu Jun 18, 2020 5:56 am
Interesting project. I recently had a frame built with the opposite seat tube - 78 degrees. Looks like that lower headset cup is seated properly on the fork now. Those brake calipers aren't standard for the group, right?
