Sy6 / Cannondale SystemSix Hi-Mod 2019 56cm / Sram Red ETAP (New Pictures)
req110
by req110
Hello team.
I had S-Works Tarmac SL6 previously, but sold it.
I got amazed by aerodynamics of this Sy6, and i can confirm that i don't care about additional weight anymore. I am faster with this bike on almost all rides i do in my area (Czech Republic, Prague and Central Bohemia).
FRAME
56cm, ALL-NEW SystemSix, BallisTec Hi-MOD Carbon, Di2 ready, SAVE, BB30a, flat mount, Speed Release thru-axle
FORK
ALL-NEW SystemSix, BallisTec Carbon, Speed Release thru-axle
RIMS
HollowGram KNØT64 Rim, Carbon, 20h front, 24h rear, 64mm deep, 21mm ID, tubeless ready
HUBS
HollowGram KNØT, sealed bearing 12x100 front, 12x142 rear centerlock w/ DT Swiss internals
SPOKES
DT Swiss Aerolite, straight pull
TIRES
Continental GP5000 TL 700x28mm
PEDALS
Speedplay Titan Zero
CRANK
Cannondale HollowGram Si, BB30a w/ power2max NG Eco Power Meter (CR2450) - Installed, Activated, Rotor Qarbon 50/34 chainrings
BOTTOM BRACKET
Cannondale Alloy PressFit30
CHAIN
Sram Red 22
REAR COGS
Sram RED XG-1190 11-28
FRONT DERAILLEUR
Sram Red ETAP
REAR DERAILLEUR
Sram Red ETAP
SHIFTERS
Sram Red ETAP HRD
HANDLEBAR
Cannondale KNØT SystemBar, carbon, 8-degree pitch adjust
GRIPS
Decathlon basic bar tape, but love it!
STEM
Cannondale KNØT SystemBar, alloy w/ cable cover + Wahoo Mount from Raceware
HEADSET
Tapered, 1-1/8" upper, 1-1/4" lower bearing
BRAKES
Sram Red HRD
SADDLE
S-Works Toupe 155mm
SEATPOST
Cannondale KNØT Carbon, 330mm
WEIGHT
Specs 7.8 kg / 17.2 lbs (56cm), measured 8.2 kg including pedals, Raceware Wahoo mount
Size, Geometry:
56
Compare
Reach 392
Stack 560
Top Tube (effective) 560
Seat Tube C-T 530
Head Angle 73.0°
Seat Angle 73.9°
Head Tube 149
Chainstay 405
Wheelbase 987
Front Centre 593
Standover 798
BB Drop 72
BB Height 269
Fork Rake / Offset 45
Trail 57
DeanKRN
by DeanKRN
Looks fast standing still!
I like the stripe of colour on the rims matching the paint! :mrgreen:
req110
by req110
Ah, that stripe is gone :)
Anyway, i love the sound / the aerodynamic noise the bike makes. My friend told me, it sound like car when it's rolling.
DeanKRN
by DeanKRN
req110 wrote:
Tue Nov 26, 2019 12:38 pm
I like that sound too, less so when the wind catches my wheels :shock: :lol:
hannawald
by hannawald
reedplayer
by reedplayer
hi
for shure a good bike.....but if you simply want your rides as fast as possible, why dont you switch to a tt-bike? i can confirm, that my tt-bike is faster than any roadbike!
however, i wish nice, fast rides further on! :wink:
regards
btw indoor pic of your tarmac is amazing.
Spacemedic
by Spacemedic
Ain’t this called “weight” weenies
req110
by req110
Yeah, weigh weenies, i am on 8.07kg with pedals, gp5000tl28 + 30 ml sealant + wahoo mount, i was considering many times to shed 200g out, but the bike works really well.
As mentioned in other thread, instead of shredding aerobike, makes more sense to buy a climbing bike and make it 4.5kg :D
Buing tt bike is not option for me, i need to handle the bike in various locations, curves, descents, etc.
Spacemedic
by Spacemedic
It's a sweet bike. You should enjoy it however you like. I was just messing :beerchug:
req110
by req110
I was thinking about aerodynamics recently.
Cannondale is mounting Vittoria Rubino Speed 23 by default. Those blow up to 26mm. I have gp5000tl28c blown to 29mm. The comfort is nice, the tires are one of fastest tires on the market.
Those Rubino's are probably more aero and around 190g + 70g inner tube = 260g total, while my conti's are 340+30ml = 370g each. I could have saved 220g, so it's very teasing. But i have now lot of comfort and low rolling resistance.
I will stick to comfort and rolling resistance for now :)
req110
by req110
Let me attach some recent pictures.
1) I've dropped cockpit to lowest position for a while, it's absolutely ok for me, but i couldn't stand the 1cm uncut fork. But i didn't wanted to cut it because that can draw back potential buyer... So i have it back on second lowest position (1 cm spacer underneath).
2) I've bought 15mm setback seatpost, my god, it feels so much better for me. (35mm seatpost for sale)
3) Tires may need change, i wish i can get some tanwall like turbo, but i need to stay tubeless.
Another option may be to buy some lighter tires, does it make sense to go from gp5000tl to 2020 pro one?
4) Garmin varia rtl510. So happy, good tool. Still waiting for delivery of this mount
https://images-na.ssl-images-amazon.com ... SX569_.jpg
