Alchemy Eros - Ti 1x road disc
Zitter
by Zitter
The guys at Alchemy were great to work with and were very receptive to my specifications from geometry to artwork to all the little details like cable port placement, EC headtube, English BB, 27.2mm seatpost, etc.
Final build photos 7.94kg as pictured
https://i.imgur.com/qU24ynr.jpg
https://i.imgur.com/XmaFSkx.jpg
https://i.imgur.com/S20tyJc.jpg
Final build list:
Alchemy Eros titanium custom geometry 1x only w/ internal routing
Alchemy carbon 1 1/2 - 1 1/8 fork matte black
Chris King i7 matte bourbon headset
Fizik Argo Tempo R3 150mm saddle
Deda Superleggero RS 27.2mm seatpost
Enve carbon 120mm -6 degree stem
3T Superergo LTD Stealth 40cm handlebars
Fizik Vento Solocush 2.7mm navy bartape
Dura Ace 9170 shifters/brakes
XTR MT900 140mm rotors
Dura Ace 9100 Pioneer 172.5mm crankset
Chris King matte bourbon steel English BB
XTR M9050 Di2 rear derailleur
Kogel 12t Ceramic Pulleys
Garbaruk 42t 1x chainring
3T 9-32t Bailout cassette
KMC DLC 11 black chain
Industry Nine i9.45TL wheelset
Continental GP5000TL 25mm tires
Speedplay Zero pedals
Arundel Mandible matte oil slick bottle cages
Wahoo Elemnt Bolt
Tune Schraubwurger seatpost collar
icantaffordcycling
by icantaffordcycling
This looks like a super sick build. I would use a garbaruk chainring instead of the wolf tooth one because it matches the profile of the crank better but that is just me. I love how aggressive your geometry is.
Zitter
by Zitter
Thanks! The Garbaruk does look nice it'd match nicely; does it need to be dremeled to fit the 9100 crank though? I know Rotor makes chainring caps and I have some Ultegra ones but they don't really match.
Zitter
by Zitter
Ah I must've overlooked it. Looks good, I'll definitely try it out!
petert123
by petert123
Zitter wrote:
Wed Nov 13, 2019 1:10 am
Building what will hopefully be my forever road bike.
We all say that! Look forward to updates...
eric01
by eric01
Subscribed! Looking forward to seeing the build!
LewisK
by LewisK
Good choice, this will be a really nice build! Looking forward to seeing it built up!
boots2000
by boots2000
With Alchemy I would make triple sure that those tires will fit. When my wife got a custom Alchemy we requested clearance for big tires but a Conti 28mm tire did not fit in the rear-
Zitter
by Zitter
The GP5000's run true to size so hopefully it's not an issue like the old 28mm GP4000's which would blow up to 30+mm on a wide rim
A few changes to the build list:
Deda Superleggero RS 27.2mm 12mm offset black on black seatpost
Zitter
by Zitter
Some final pieces, changed my mind again and went with the matte bourbon headset & bb. Frame should be arriving any day now and the drivetrain will be donated from my Orbea
Edit: frame arrived
modified rear brake hose exit
kode54
by kode54
That CK matte bourbon color looks so nice!
- Factor 02 Disc + DA9170 + Enve 4.5AR CK CL hubs
- Moots Vamoots Disc RSL Titanium + DA9170 + Enve 3.4AR CK CL hubs
- Parlee Chebacco + DA9170 + Enve G23 CK CL hubs
- Allied Able + DA9170 + Enve G27 CK CL hubs
mike
Resident Pro
by mike
I would go with bebop titanium pedals instead of the speed play since the bebops will be lighter for both pedals and cleats (145 grams for pedals and cleats 60 grams) and shed mud easier and easy for you to walk around if you use spd shoes. The pedals can also be used with standard 3 hole shoes as well. Though bebops are no longer made I saw a titanium one on flea bay just the other day
Zitter
by Zitter
I actually may get a set of Zero Pave's since I like the aesthetic
Final build photos, just waiting on a Tune seatpost collar. 7.94kg as pictured
icantaffordcycling
Looks great! How does the jump from the 9t to the 11t feel?
