Time to kick off the build thread. Base bike is a 2019 SuperSix EVO Hi-Mod Disc.
Estimate is based on a 7.7kg stock bike weight (56cm) and my calcs (see below). Estimate is 6.83kg with everyday wheels/tires and 6.35kg with special event wheels/tires.
Starting weight is variable most likely to throw off the final result, as I am basing the 7.7kg solely on an article I found online listing that as the stock weight. The other variable is that I had the frameset custom painted, and I don't yet know know how much weight that added (the paint looks like shite BTW and I will need to get it re-done). The final variable is that a few weights are estimated, including the Deda Alanera DCR bar/stem that I *think* I will be using, though it's not yet released.
For now, here is the build sheet and my calcs:
It's not spelled out in the spreadsheet, but with the Cyberdisc wheelset, I'm going to run an Omni Racer 11-28 cassette and Corsa Speed 2.0 TLRs in 23c, so that explains the weight savings between the two wheelsets.
