2020 Supersix Evo Hm
raph37
by raph37
Current setup:
Frame: supersix evo hm replica size 56
Groupset: ultegra 8070
Crankset: s works powermeter 175 50/34 610 grams ( Will change the ring soon for a praxxis)
Bar stem combo: black inc 345 grams with garmin mount
Pedal: dura ace 9100
Saddle: Specialized oura with carbon rail (the one fitting my bottom)
Wheelset: custom 44mm and 22mm inner width with new 180 ratchet exp hubset and aerocomp spokes for an heavy rider 1450 grams, turbo cotton tires, xtr 160 rotors and sram xg1190 tuned 12/30
Actual weight as pictured: 7,1 kg
Dan Gerous
by Dan Gerous
Nice! And good weight without crazy light parts.
takos03
by takos03
Very nice build! Beautiful frame..
cerro
by cerro
raph37: How did you get that crank to work with BB30a? No bearing adjust and just a wavy washer and maybe some shims?
/jonas l
raph37
by raph37
cerro wrote:
Tue Nov 05, 2019 9:11 pm
Exactly: 1 shim and 1 wavy washer and it works perferctly
refthimos
by refthimos
We tried to get the S-Works PM to work on my SystemSix, but the spindle is just soooo short that we couldn't get it to clear. I may give this PM another run on my EVO3 build, but for now it will be SISL2 with SRM, which is pretty close (through not quite as light) as the S-Works.
EVO1 | 5.37kg
EVO3 | 6.51kg
SystemSix | 8.01kg
P5 | 9070 Di2 | SISL2 SRM | Enve 7.8/FFWD Falcon | Roval 321
T1 | P2Max Type S | Rolf Prima FX58/Zipp Super 9 Disc
raph37
by raph37
refthimos wrote:
Wed Nov 06, 2019 12:44 am
Have you removed the bearing adjuster on the left side of the Cranks?
bikeboy1tr
by bikeboy1tr
This is an extremely nice build and now that I see you getting a disc bike to that weight without too many super light parts makes me want to have one. That wheelset must be extremely light to get a disc bike to 7kg. Anything special for caliper hardware and discs?
viewtopic.php?f=10&t=154188
2018 Colnago V2R Rim Brake
2012 Time RXRS Ulteam Rim Brake
2008 Time VXR Rim Brake
raph37
by raph37
bikeboy1tr wrote:
Wed Nov 06, 2019 9:58 pm
Nothing special about brake system. The wheelset weight 1450grams: no so light but built for stiffness and use bit tires
iamraymond
by iamraymond
That's a really impressive weight considering all the integration and the wheelset you've chosen.
I'm interested in the tuned xg1190 12-32 cassette. You have any more details on that?
Dan Gerous
by Dan Gerous
Encouraging for my aim to eventually build one under 6.8kg.
raph37
by raph37
iamraymond wrote:
Thu Nov 07, 2019 10:19 am
11t cog removed on a 11/26 xg1190 then I put a 30t miche last position sprocket. So finally I have a 12/13/14/15/16/17/19/21/23/26/30 range cassette and it works fine
raph37
by raph37
Dan Gerous wrote:
Thu Nov 07, 2019 6:06 pm
Pretty easy with speedplay pedals, lighter saddle and bike ribbon, forget the powermeter to and you won’t be far of 6,8kg
raph37
by raph37
raph37 wrote:
Thu Nov 07, 2019 10:09 pm
And dura ace di2 instead of ultegra di2
Dan Gerous
by Dan Gerous
raph37 wrote:
Thu Nov 07, 2019 10:33 pm
My plan would be with DA Di2 indeed, XTR rotors, Hollowgram SISL2 with SpideRing SL, different bar+stem, wheels (not sure what yet, DT's PRC 1100 25Y maybe?), tubeless tires (either new Schwalbes or new Michelins that will be out early 2020)... but I'd stick with DA 9100 pedals, I used Speedplays for years, way too much maintenance for me.
